Lightweight seats retrofit
Old Sep 27, 2017 | 07:22 AM
bunob's Avatar
bunob is infamous around these parts
Hi all,
I'm trying to retrofit DBS Lightweight seats into a V8 Vantage from 2006.
- Firstly, not the same Seat Position Adjustment Switch :
Mine ... New one
Electrical connectors : ...... 3 ............................. VS ...................... 1
- Secondly there is 2 release switch (Seat Convenience Switch), one on each side.
The wiring harness is different...
Does someone do this retrofitting ?
Any help will be appreciated ;-)
Pics from the wirings, without the seats, etc...
Old Sep 27, 2017 | 03:41 PM
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
You're probably better asking this on Pistonheads as lightweight seats are not an option in the USA (sadly).
Old Sep 28, 2017 | 06:05 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Memory seat control panel
It appears that you are trying to replace the standard seat controls with memory seat controls.
Memory seats first became an option on the MY07 Vantage, so your MY06 most likely won't have the correct wiring harness or file.
With the correct wiring diagrams, you might be able to make your original switches work.
Good luck!
Old Sep 29, 2017 | 06:08 AM
bunob's Avatar
Thanks,
I know the wiring is different, The ECU under the seats are différents and connectors too...
Do you know if I can found only the wiring seats or if it is the entire electric wiring ?
I know that DB9, DBS, Vantage since MY08 (V8 & V12) have new Seat Position Adjustment Switch with only one connector.
Old Dec 5, 2017 | 01:35 AM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
Still working on this? I have a line on some beautiful original Vantage carbon fiber light weight seats. Would probably be a much easier retrofit than the DBS lightweight seats. Let me know if you're interested and I will connect you with the source.
Old Dec 5, 2017 | 02:39 AM
bunob's Avatar
Yes I'm still working on...
Old Dec 5, 2017 | 08:30 AM
Do you need seats?
Old Dec 5, 2017 | 08:58 AM
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
What do the lightweight carbon seats look like? Have any pics or a site for me to see them?
Old Dec 5, 2017 | 10:04 AM
skywagon's Avatar
skywagon is a jewel in the roughskywagon is a jewel in the roughskywagon is a jewel in the rough
Are they the same ones that Kanga references above? I might be interested in them depending on color and if the door cards (or even just the door card inserts) are available as well. Feel free to PM me.
Old Dec 5, 2017 | 02:34 PM
era2076's Avatar
era2076 is infamous around these parts
I have a line on some beautiful original Vantage carbon fiber light weight seats. ...... Let me know if you're interested and I will connect you with the source.
I am interested - are they still available?
x-chr
Old Dec 9, 2017 | 01:25 PM
bunob's Avatar
