Door/Window trim out of alignment?
Old 10-12-2017, 10:21 AM
silver997's Avatar
silver997 is on a distinguished road
Anybody have this problem? I have to special order the trim piece on the door and it's not returnable. Will replacing the trim piece fix this?
Old 10-12-2017, 10:56 AM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Not sure trim will fix that. Has the door ever been adjusted?
I had a door on a Corvette adjusted years ago, and after that it caused me nothing but issues. I almost suggest leaving it be. Trim wont help. You would have to have less material under it for the top part to lay lower, and the same on the door to get it flatter. New trim will be the same as your trim now. IMHO
Old 10-12-2017, 11:16 AM
silver997's Avatar
The door has never been adjusted. AFAIK. No accidents. Both driver and passenger sides are like this. When I push on the door trim there is no flex or give to it. It's like the rubber portion has hardened or something.
Old 10-12-2017, 11:35 AM
SheriffDep's Avatar
Not sure how they install. Rich at REDPANT.lol should know. However, it is possible the rubber below the trim piece did harden, which then pushed it up enough to be noticeable. Without knowing exactly how they are installed and knowing what materials are below the metal trim, I cannot help with that. But that is a possibility.
If that is not the case, then I likely wouldn't touch it. More issues may arise that aren't acceptable as this might be.
Old 10-12-2017, 11:49 AM
embdenb's Avatar
embdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to beholdembdenb is a splendid one to behold
I had a door on a Corvette adjusted years ago, and after that it caused me nothing but issues.IMHO
+1
Trim is not your problem, the door itself is out of alignment. This issue is aligning the door trim while maintaining the door gap to the fender and body.
If you are not sure what to do have a qualified body shop look at it.
Old 10-12-2017, 01:31 PM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
Roughly the same on my 2006 with 70k miles.
Keep us posted.
Old 10-12-2017, 04:45 PM
silver997's Avatar
Open the door roll down the window. The trim just pulls off. Lift up carefully.
Tape off the edge and gently with pliers bend the metal in towards the interior. This might take a couple of tries to get just the right amount of bend into the edge. Be careful not to crack the paint.
I also loosened the door striker and adjusted it a couple of mm towards the interior.
The results......
Here is the passenger side. Looked the same as the drivers before I started
Old 10-12-2017, 06:53 PM
era2076's Avatar
era2076 is on a distinguished road
Nice work - Thank you for posting.
chr
Old 10-13-2017, 10:50 AM
rohnin's Avatar
rohnin is on a distinguished road
My brand new car came with worse alignment issues: doors (like yours), trunk, and worst of all the rear wings badge! Very disappointed in quality control
Old 10-15-2017, 10:09 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
interesting, looks like my trim piece is just a bit loose then, thanks for the pics.
Old 10-16-2017, 04:11 AM
larryg's Avatar
larryg is on a distinguished road
Interestingly my 14' Vantage came with perfectly aligned doors.
The round gas filler cover however had some alignment problems that were easily rectified with 1/16th inch nylon washers.
