Checking for timing cover oil leak
Old Oct 26, 2017 | 11:09 AM
mackorbuddy's Avatar
mackorbuddy is infamous around these parts
Hello all, I'm going to look at a 2007 Vantage tomorrow. The car has new tires, newish brakes and a brand new AMR clutch. Besides bodywork (which I'm going to check out with a paint thickness meter), the other issue I'm most concerned about is the timing cover oil leak. Is there a way to check and see if this is a current issue from the top? On this visit I won't have access to a lift.
I searched old threads and didn't see any mention of this, perhaps I missed something though.
Thank you!
Travis
Old Oct 26, 2017 | 11:12 AM
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
You'll need to look underneath the car to check for the leak.
Old Oct 26, 2017 | 11:16 AM
That's what I was afraid of, thank you Rich.
I was hoping to be able to tell from a cursory inspection...if the car is really leaking then I could rule this car out and avoid spending $600 on a PPI.
I've called my local dealers and they quote $7-8K in labor for the reseal job(!)
Speaking of which...can anybody recommend an independent shop near San Francisco?
Old Oct 26, 2017 | 11:45 AM
embdenb's Avatar
Get on your knees and look underneath the car. You can see the bottom of the timing cover.
Any leak should be readily apparent. Also check the vin with a dealer, they should be able to tell you if and when the timing cover gasket was changed.
Old Oct 26, 2017 | 11:48 AM
embdenb's Avatar
Had my timing cover gasket replaced at the dealer about a year ago. Cost was about $3K.
You are dealing with the wrong dealer
Old Oct 26, 2017 | 01:33 PM
J doubleU's Avatar
You could always buy an inspection mirror at auto parts store, sears, harbor freight. They use to be the go-to before fancy cameras.
Old Oct 26, 2017 | 01:50 PM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
I owned a 2007 Vantage Coupe for 3 years. I bought it used in 2014 from my local Aston Martin dealer. It came with a 1 year preowned warranty. I know a 2007 is beyond the preowned warranty now. I would still have a dealer look the car over, and have them run the vin# for the service records (has others have said). My car was a stick and had 2800 miles on it when I bought it. And had 7000 on it when I traded it in. It was a very reliable car. I had the door struts replaced, and the seat heater and goes filler door release replaced under warranty. Has well as the rear shocks, pluse the Nav door gear replacement.
And that was it. These are great cars. Just make sure you purchase a good one with history, if you can.
Ron
Old Oct 26, 2017 | 02:02 PM
Thanks, all! This will be my first time inspecting one this closely, I called the seller and he's arranged to have a lift available so we should be set.
The car has a pretty good service history and I've got calls in to both of the service centers listed on the carfax to try and fill in any gaps.
Fingers crossed, thanks for the advice!
Old Oct 26, 2017 | 02:04 PM
YES! I plan to do routine maintenance myself, but I need to find a good independent shop!
Old Oct 26, 2017 | 06:07 PM
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
I'm pretty sure you need to drop the undrtray
Make sure you have the right torx bits with you
And good luck
Graze
Old Oct 26, 2017 | 06:38 PM
And good luck
Graze
Great tip, thanks! I'll take a set of bits along just in case.
Old Oct 27, 2017 | 10:54 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
My dealer quoted me 4K for that service.
Old Oct 27, 2017 | 01:47 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
If it's on a lift you can see the cover clearly without removing the tray. If it's leaking it'll be all over the bottom of the cover.
Old Oct 28, 2017 | 08:36 AM
Thank you for the responses, everybody. We put the car on a lift after a test drive and there was zero indication of an oil leak...no need to remove the cover to see it.
Anyhow, everything checked out so there’s a white 2007 Vantage headed my way!
Old Oct 28, 2017 | 10:01 AM
Ron Avery's Avatar
Cool, good for you. What are the colors and options? Is is a solid white or metallic?
Ron
