Quickjack
Old Nov 22, 2017 | 08:05 AM
  #31
rocketboots999's Avatar
rocketboots999 is infamous around these parts
Originally Posted by NCVantage
Also worth noting that they have little wheels on one end so you can pickup the other end and move them around pretty easily without having to carry the full weight. There are also two positioning bars included for helping move the units around under the vehicle.
Hmmm, it's looking like this might happen! A couple more questions if I may?
- I haven't had to jack up my "new to me" car yet and I have read some of the horror stories about it being done wrong. How does the Quickjack pick up on the car's jacking points? Does it have adjustable mounting points for different cars? Someone mentioned using the Quickjack with custom Vantage jack fittings advertised on this forum; is that really necessary?
- With so many size variations, I need to pick a Quickjack model that won't be useless for other cars should I move on from the Vantage; I may eventually get another classic car. Any thoughts on which model is a good all-rounder?
Old Nov 22, 2017 | 08:14 AM
  #32
NCVantage's Avatar
NCVantage is infamous around these parts
Originally Posted by embdenb
If they ever come out with a design that bolts permanently to the garage floor I would buy one. Too heavy for me to lift and store with my health issues.
There are low rise scissor lifts that might work better for you. I've not used them but looked at them before deciding on the Quickjack. Here is one example:BendPakP6 With this one you can even get a version that can be flush mounted in the garage floor. Downside is that this is a bit more money...about 1k more than Quickjack, but may fit your specific needs better.
Old Nov 22, 2017 | 08:55 AM
  #33
NCVantage's Avatar
On the top of each Quickjack, there is an open tray at each end. The size of the tray (length) depends on the model you pick. In this tray you position solid rubber lifting pads. You get two sets, one "Short" and one "Tall". You just position the Tall or Short pads at the points in the tray that line up with the lifting points of your specific car. The owners manual should point those out for you.
Now for the Vantage (and other AM models) the lifting points are odd shaped areas. The custom lifting pads are not necessary, but very helpful. You can use the standard pads you get with the Quickjack or blocks of wood for that matter, but you run the risk of pinching/compressing/cracking the body panel that wraps under the car at the lifting points. I would highly recommend them for our vehicles. I also bought a set of pinch weld lifting blocks on Amazon because many cars (including my kids), you lift from a pinch weld (not a flat area).
As to your question about which model, that is tough because it depends on what other vehicles you have or will get. For me, a wanted the biggest version I could get so I could lift all the cars I have and my truck and SUV, so the 7000EXT was my only option. There are two major differences between the models based on my own research (I'm by no means an expert on the Quickjack), the lifting capacity and the length of the units. The SLX versions of the 5000 and 7000 are 70" long while the EXT version of the 5000 and 7000 are 76" long. There is even a 6000 XLT which is 86" inches long. I tend to buy based on the "Bigger is Better" model , but you also have to make sure that the unit will fit between the front and rear wheel. Again, for me, even the 7000 EXT fits under the Vantage and between the wheels...it's close, but it fits. There are other differences between the units such as minimum collapsed height...somewhere between 3 - 3.6 inches and min and max distances for the positioning blocks. Now, if I haven't completely confused you, happy shopping!
Old Nov 22, 2017 | 09:43 AM
  #34
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Thank you so much, this helps a whole lot!!!!!!!!!!! Will be in contact in a few weeks.
Old Nov 23, 2017 | 12:06 PM
  #35
karlfranz's Avatar
Old Nov 28, 2017 | 12:56 PM
  #36
Just ordered a BL-5000SLX from their website. Used the code "MONEY" mentioned in another thread for a $100 discount. Looking forward to using my new toy on my new toy.
Old Nov 29, 2017 | 11:45 AM
  #37
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
Thanks for the heads up. Went ahead and ordered one as well.
Old Dec 5, 2017 | 06:30 PM
  #38
J doubleU's Avatar
Just seen an advert for the $100 off for this month (HOLIDAYSTEAL) @ quick jack. And as always free shipping.
Old Dec 5, 2017 | 08:37 PM
  #39
DetomasoGTS74's Avatar
If you have the room, I prefer the 4 post route with sliding jacks in the center. All the benefit of lifting the entire car up off the ground (or lift) to do wheel/brake work but also protects my back more and has added another space in the garage!
Old Dec 6, 2017 | 11:20 AM
  #40
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
They even sell these on amazon http://amzn.to/2BOe73w although they seem to be a bit more expensive than ordering directly from quickjack's website
Definitely going to pick up a pair in early summer, these would be perfect for my small garage
Old Dec 6, 2017 | 01:36 PM
  #41
davidm17's Avatar
5 Year Member
Received my jack, but haven't put it together and used it yet. Shipped the same day I ordered it. I'll take some pics when I use it the first time. Might be a couple weeks yet.
Old Jan 10, 2018 | 01:36 PM
  #42
OnyxVantage's Avatar
OnyxVantage is infamous around these parts
Quick Jack 5000SLX
... just an awesome product. Using mine with Matt’s - HSM Precision pads - top notch ...
Old Jan 11, 2018 | 12:03 PM
  #43
Teekster's Avatar
Teekster is infamous around these partsTeekster is infamous around these parts
I can vouch for them as well. Great product if you don’t want to go with a 2 or 4 post lift.
Old Jan 11, 2018 | 12:06 PM
  #44
handyman2009's Avatar
Veteran: Canadian Forces
Same here love it and feel a lot safer under the car
Old Jan 14, 2018 | 05:24 AM
  #45
Scotty4300's Avatar
Scotty4300 is infamous around these parts
About the exact position of the jacking points on the Vantage.
I just use the rubber blocks supplied with my Quickjack.
I make sure that the block is middled on the bolt head at the jacking point.
Never had a problem.
