Quickjack
Old Oct 12, 2018 | 01:24 PM
  #61
MRCW's Avatar
FWIW just got my latest Costco ad and it has 5,000# quickjack for $1100 delivered.
Old Oct 12, 2018 | 01:29 PM
  #62
handyman2009's Avatar
Veteran: Canadian Forces
that is an amazing price
Old Oct 12, 2018 | 01:31 PM
  #63
MRCW's Avatar
Yes. I was going to get the 7,000# but at this price, most of my cars are at or under 5000# so I just ordered one as early Santa gift
Old Oct 13, 2018 | 07:40 PM
  #64
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
i just ordered mine from Costco, too good a price to miss.
Old Oct 14, 2018 | 12:01 AM
  #65
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
As a couple of members in this thread mentioned, I am now using my QJ with the 4" blocks instead of the 3" and the special lifting pucks. The pucks wouldn't stay in the holes, so trying to line those up, raise the jack just a bit, and then lining it all up was such a pain. So tried the rubber blocks and voila made it easy. Love the QJ, for oil change, and all my detailing work. Can leave the car up on it all week too which helps get little things done with the wheels off.
Old Oct 16, 2018 | 04:52 PM
  #66
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Just like joining a club
Ordered a Quickjack from Costco today. Waiting 5 to 7 days for delivery. I am thinking life just got a little bit easier. Looking forward to using it!
Old Oct 16, 2018 | 07:00 PM
  #67
5 Year Member
Excited
look what arrived today from Costco. I can’t wait to try it this weekend.
Old Oct 17, 2018 | 08:47 PM
  #68
SheriffDep's Avatar
YOU NEED 2.5 quarts of Automatic Transmission Fluid to make it work. Pick that up before you plan to put it together. Any fluid will work, synthetic or otherwise. Pour it in the reservoir and make sure the cap is tight, but make sure the vent is not tight. I left mine tight, and about vacuum crunched the reservoir when raising the lift.
Also-----you will need a SMALL amount of compressed air to fill the two small tubes. 50lbs each max. It takes a very very very small amount of air to get them to 50lbs.
Use the 4" blocks right under the holes for lifting and you will be set. Raise the lift partially up and down several times before using with car. DOnt raise it all the way up without weight on them.
Hope all that helps, love mine alot. Got a M3 on it right now and been in the air for a week now.
Old Oct 17, 2018 | 11:40 PM
  #69
OnyxVantage's Avatar
OnyxVantage is infamous around these parts
The Quick Jack videos will also help you to get the setup perfect.
cheers
Old Oct 18, 2018 | 06:47 AM
  #70
5 Year Member
Thanks guys. I was going to ask about th oil. I’ll do this on Friday (day working from home).
Old Oct 19, 2018 | 04:16 PM
  #71
MRCW's Avatar
Got mine today while i was out fishing...
just in time for oil change and brakes on my daughter's BMW
