Fuel Tank Overflow Hose
Old Dec 17, 2017 | 12:05 PM
flittlejr's Avatar
flittlejr is infamous around these parts
Question Fuel Tank Overflow Hose
[FONT="Arial Black"][/FONT]
Yesterday saw rubber hose dragging ground from left rear. Pulled and about a three foot piece of hose came down along with a plastic clamp and plastic push in attach. Sure it's from fuel filler compartment bottom for overflow. How hard to attach-straight up or need to be fished? Thanks Frank
Old Dec 17, 2017 | 04:35 PM
flittlejr's Avatar
Overflow hosr
Originally Posted by Redpants
If it's the overflow drain hose, it's a simple thing. Attached to the fuel filler drain, and to the LH fender liner. Pull the fender liner loose and you should be able to fix it.
I saw dragging ground when got home..Ground end of rubber ,reached under, gave hose a tug ,dropped down with plastic screw holding to body. Something I can finally do myself. Thanks Rich
cosworth
Jan 14, 2016 09:44 PM
dgreen78
Apr 11, 2015 03:17 PM
cosworth
Dec 10, 2014 06:33 AM
msv
Nov 29, 2008 04:45 AM
trojanman
Jul 23, 2008 09:27 AM
