Tail light modification
Old Jan 28, 2018 | 01:28 PM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
Originally Posted by divetheworld
Yes and yes... Send us a structurally good set of tail lights, we do all the work and you self fit back in.
There is a small wiring mod to the car to add two simple wires. The multiplug in the tail lights has spare pins, we give you the bits to clip in the extra two pins needed. That makes them plug and play and reverse compatible with standard lights.
The two extra pins are to allow the ignition on sequence because there is no feed to the lights letting them know when you start the car.
Gotcha.. Thank you.
So the lights having a history of condensation isn't a problem because you'll be sealing them back up again regardless?
Old Jan 28, 2018 | 01:35 PM
divetheworld's Avatar
divetheworld is infamous around these parts
Originally Posted by speedracer800
Gotcha.. Thank you.
No probs. Glad to help.
If the casing (lens or back case) isn't cracked or otherwise damaged, then we solve the problem.
They can be totally fubar'd, full of water and all the LED's and driver board toast. If the case is in good physical condition (can be sealed) then we sort it, all in the cost.
It's a total re-manufacture only retaining the black back, front lens and reflector. We block the OEM vent and fit two new Goretex ones. We seal the multiplug and after replacing all the innards, we properly seal the lens to the case.
Old Jan 28, 2018 | 07:22 PM
Judd986S's Avatar
Judd986S is infamous around these parts
service to the US? I was looking at getting a new rear light as my turn signal function no longer works on the right side.
edit: wow, long time lurker as this is my first post in 7 years! I had a Boxster S when I joined then went to a 911 Turbo, then a 911 Cab.
I now have a DB9 Volante. do you need the third light for any reason?
Old Jan 29, 2018 | 12:38 AM
Happy to supply the US direct. Email us and we can chat about your needs. Don’t require that third brake light.
Old Jan 29, 2018 | 01:08 PM
Thank you again for the information. I'm looking for a pair to send in as I don't want to modify the perfectly good pair in my car currently. It makes more sense to source another set in need of re-sealing due to condensation etc. Then keep my original units untouched.
I checked out the website again and ordered one of those billet oil caps for the V12.. Those are really trick! Lots of cool parts on your website!
Old Jan 29, 2018 | 01:33 PM
drivergmx's Avatar
drivergmx is a jewel in the roughdrivergmx is a jewel in the roughdrivergmx is a jewel in the rough
Do you offer exchanges for Original AM CF parts with defects? Such as DBS front splitters with curb rash or diffusers with stress cracks in the clear coat?
Old Jan 29, 2018 | 01:51 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I received one of those for Christmas.
It's beautifully made -- looks like jewelry under the hood!
Old Jan 29, 2018 | 02:02 PM
Kind words are much appreciated.
We tend to make something for our own cars and then think that they'd make a nice product.
Those oil caps do look nice if you've bought some of these aswell ... https://www.modsticker.com/products/...o-Sticker.html
I'm afraid not. Yo do know you can get that repaired quite easily? It's a matter of economics, DBS splitters are cheaper to replace than repair. A diffuser, not so much and worth repairing.
Old Jan 29, 2018 | 03:23 PM
drivergmx's Avatar
Has anyone ordered these yet? Looks pretty cool. Send them your tail light assemblies for modification. About $1500.. Kinda steep.
http://www.divinatech.com/ASTON-BACK...seq-lights.htm
​​​​​​https://youtu.be/2aEYC1EbCt4
Yeah, I must have these now... These plus the clear markers and smoked reflectors I just ordered from Redpants.lol. It just keeps getting better...
plenum
Jul 5, 2015 05:25 AM
kocsis
Cayenne 958
Dec 23, 2012 08:32 AM
akbjr
Aug 4, 2010 09:59 AM
notquitefob
14
Jan 16, 2008 03:05 PM
SHANKENFELTER
Dec 28, 2004 09:53 AM
