AOS and O RING
Old Mar 19, 2018 | 11:53 PM
cadman's Avatar
5 Year Member
cadman is a jewel in the roughcadman is a jewel in the roughcadman is a jewel in the rough
AOS and O RING
just pulled the AOS out for inspection and cleaning,sure enough it is leaking at the O ring,as covered in past threads. the part # on the AOS is 6G33-6B673-AA , checking out a new AOS the part # is 6G33-6B673-AB.
just wondering if the AA to AB means it has the updated O ring ?
Old Mar 20, 2018 | 01:47 AM
Graze's Avatar
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
Probably stupid question but AOS is what exactly?
Graze
Old Mar 20, 2018 | 02:19 AM
Logannz's Avatar
Logannz is infamous around these parts
I understand the newer o-ring is deliberately fatter to prevent the on-going leaks. My replacement fitted very nicely and was noticeably larger
AOS is Air-Oil separator
Old Mar 20, 2018 | 02:28 AM
Logannz's Avatar
Sorry I didn't read your question very well, yes as I recall the AB is the newer o-ring, however I think only the fatter one is supplied now. My dealer only had the larger type.
Old Mar 20, 2018 | 05:46 AM
cadman's Avatar
5 Year Member
thanks Logannz, i was hoping it was updated. just wanted confirmation ,after reading the old thread from back a few years "member irish" pointed out that a new AOS would not solve the problem,only the fatter O ring would. glad to here that AM picked up on this problem and the new AOS comes fatter fitted...
Old Mar 20, 2018 | 10:18 AM
embdenb's Avatar
Graze
Air Oil Separator
Its function is to separate the oil (from the air) and return it to the engine
Old Mar 20, 2018 | 04:00 PM
Graze's Avatar
thanks lads
got it & have a Redpants catch can fitted too
Graeme
Old Mar 21, 2018 | 11:00 AM
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
Does this part apply to 2013 V8 vantage ? 6G33-6B673-AB
I never replaced mine, have 7K mile on my car, maybe i should. i called galpin parts dept, they want $65 I think it's little too much..
Old Mar 21, 2018 | 01:13 PM
007JB's Avatar
Originally Posted by Redpants
6G33-6B673-AB is for the whole separator, you only need the o-ring. If yours isn't leaking, I would just leave it alone. Once it does leak, then replace the o-ring. The leak is more of a seeping - you'll notice oily grime building up on the separator and hose coming from the bottom of the separator.
Thanks Rich. I guess that explains the cost.. Do you have part # for o-ring,
Do you sell this parts?
Old Oct 15, 2018 | 10:05 AM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
Looks like a new OEM AOS unit #6G33-6B673-AB is ~$35 and a straightforward DIY job. Still wondering if the O ring itself is available separately since that is the faulty part. Anyone using an alternative from Ford, Jag etc.?
Parkcity911
Apr 4, 2015 05:45 AM
stilov
Jan 3, 2014 05:47 AM
May 16, 2011 09:45 AM
Dervish
Jan 1, 2011 02:58 PM
