Leak, what could it be?
Old May 9, 2018 | 06:30 AM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
I noticed a very small amount of what appears to be oil on in my garage from where the car had been sitting w/o being moved for a month, where it had just come back from being in the shop for its annual. I'd get under it to try and take a look but it's actually in for some paint work for the next couple wks at least.
Any idea of what it may be? I realize it's a pretty open ended question but just wondering what "typically" could leak on our cars. Thanks in advance.
Old May 9, 2018 | 06:33 AM
embdenb's Avatar
Timing cover gasket?
Old May 9, 2018 | 06:53 AM
last I had that checked it was very slowly forming single drops, but I will double check that again w/the tech that was working on my vehicle.
Old May 9, 2018 | 07:05 AM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
O ring on the EGR valve
Old May 9, 2018 | 07:40 AM
never heard of that, could you elaborate at all?
Old May 9, 2018 | 09:31 AM
Vantagelvr's Avatar
Dont know why I typed EGR was meaning PCV valve theres a O ring that they now use a different slightly thicker section O ring in the housing I believe . I think I remember it being talked about in redpants thread about his catch cans .
Old May 9, 2018 | 09:43 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I had a timing gasket leak that started on my 2015 GT - was covered under warranty - they showed me the gasket was pinched while original build. They took the front end of the car apart to get to it, but was covered under warranty. Was more of a seep but would have been a minor leak eventually.
Old May 9, 2018 | 02:39 PM
Originally Posted by Redpants
It'd have to be leaking pretty but here's this:
https://www.redpants.lol/air-oil-separator
Only other thing I can think of would be the timing cover gasket, unless there's something loose or disconnected.
yeah it's not leaking much, 2 smallish "puddles" in total less than a foot wide and separated by a few inches. don't think it's PCV valve since I just replaced that last year, the catch can did just get emptied so I'll double check all the fittings when I get the car back. it'd be a real bummer if the timing cover was doing the seeping as I didn't think it was forming but like a drop here and there (it was fixed by PO 2 yrs ago but at this shop, not the dealer, really grinds my gears it's seeping at all).
Old May 14, 2018 | 08:45 PM
Vantage007's Avatar
Vantage007 is infamous around these parts
I'm new here but it sure sounds like the timing cover gasket is pretty common, at least the posts I have been through so far it sounds like it? How costly of a fix is that?
Old May 14, 2018 | 11:40 PM
2-3 grand depending on your local labor rate.
Dale D
Cayenne 955/957
19
Aug 12, 2018 06:45 AM
TJtheDJ
Cayenne 958
Dec 2, 2016 09:18 PM
pors968
Cayenne 955/957
Jul 29, 2015 07:43 AM
MadWhip
Feb 21, 2015 05:23 PM
