Aston Martin vantage 06 v8 electric problem
Old Jun 2, 2018 | 12:54 AM
_R_Castro's Avatar
_R_Castro is infamous around these parts
Hi I'm new to the forum and Aston Martin world.
I have taking over a 2006 v8 vantage that has not been started sense 2014..
I just got the car running But my dash and all the rest of the electric to the car Is dead and I have a rattle ticking sound from the boxes.
I puta link below of a clip I posted on YouTube.
do any one of you recognise the problem?
https://youtu.be/8Drsvi6KXzg
best regards
Rodrigo Castro
Old Jun 2, 2018 | 05:25 AM
cadman's Avatar
5 Year Member
cadman is a jewel in the roughcadman is a jewel in the roughcadman is a jewel in the rough
did it start under battery power or was it jump started ?
after so many years i would without doubt start the trouble shooting
with a brand new battery..
Old Jun 2, 2018 | 06:09 AM
_R_Castro's Avatar
Hi
I bought a new battery. And it started . But dash and radio and lights are dead ..😖
Old Jun 2, 2018 | 01:53 PM
superuser's Avatar
superuser is infamous around these parts
Originally Posted by _R_Castro
Hi
Is it possible that the light dimmer is all the way down?
Old Jun 2, 2018 | 03:43 PM
J doubleU's Avatar
Power supply fault. Disconnect the negative side cable, ensure the key is in hand (not in ign) reconnect battery and cycle battery "on" button at the bottom of battery on the + side. Shut all the doors, hood,hatch. Then lock/unlock with key or remote. Remote FOB may not work due to age of internal battery. Then attempt key in ignition to start.
Old Jun 3, 2018 | 04:56 AM
_R_Castro's Avatar
i got a tip that it could be in crash mode . The car have been in a little accident. Do any one know how to reset the crash mode?
Old Jun 3, 2018 | 07:45 AM
J doubleU's Avatar
AM dealer required
Old Jun 16, 2018 | 05:17 AM
_R_Castro's Avatar
Hi my problem was the cembox under the glowbox on the floor passenger side. I need to program the box I ordered now
Old Jun 16, 2018 | 08:06 AM
J doubleU's Avatar
CEM needs programming by a dealer along with keys and remote FOBs. You will likely need new remotes as you need the codes to enable them for reprogramming to new CEM.
Old Jul 16, 2018 | 05:40 AM
_R_Castro's Avatar
im waiting , for my cem box getting back..
thanks for the support
Old Jul 18, 2018 | 07:14 AM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
I also have a 2006 V8V. I had to replace my CEM a couple of years back. The CEM is a Volvo unit. If you plan on replacing it you will need the car config file from AML in addition to AMDS & the key codes to compete reprogramming. If these are not available to you, you may be able to get it repaired by a Volvo electronics specialist and they can retrieve the car config from the existing module.
I also listened to your video. It actually sounds like you have a sticking relay on the CEM. Try replacing the two relays I'm pointing to in this photo. The second pic is the Volvo part info for the CEM.
Relays on AMV8V CEM module
2006 AMV8V Volvo CEM Part Information
Old Jul 3, 2024 | 10:27 AM
whiskeybusiness's Avatar
whiskeybusiness
Does the fan also run while the key is out of the ignition? If so I think I may have a solution for you. Just fixed a similar issue, relays would click and fans would run until the battery was dead with the key out. Otherwise, the car worked fine.
https://www.6speedonline.com/forums/...ngine-off.html
Global Autosports
Mar 21, 2012 10:19 AM
Global Autosports
Mar 19, 2012 09:11 AM
