V8VS Rotor Thickness Specs
Old Jun 21, 2018 | 02:35 AM
Cobra66's Avatar
Cobra66 is infamous around these parts
Smile V8VS Rotor Thickness Specs
Hi All, I was hoping someone could direct me to where I can find the specifications for serviceable rotor thickness for a 2012 V8 Vantage S front & rear Rotors. I can find diameter etc but not minimum thickness? At my last service 10 months they predicted I would need new Rotors and Pads all round. While I have no reason to doubt the advice I would like to be able to check for myself just to be sure. In a previous set of posts I mentioned I planned aftermarket replacements on both rotors and pads and got some good feedback.
On a side note I have had the car for just on a year and the more I drive it the more I like it. It has lived up to all expectations. I have recently been on a long drive to the Great Ocean Road in Victoria in Aust and onto the Barossa wine districts, a 5000k round trip over 10 days and it was great.
Regards Cobra66
Old Jun 21, 2018 | 02:54 AM
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
Cobra
i'm pretty sure fronts are 32mm original & 30mm min , rear are 28mm original & 26mm min
thats for my 07 4.3L - think it applies up to 2012
yours may differ but I doubt it
Graze
Old Jun 26, 2018 | 02:09 AM
Cobra66's Avatar
Hi Graze, I appreciate the reply. My car is a V8 Vantage S and has 15" front rotors and 13" rears. I believe the rears are the same as the std Vantage so the 28mm and 26mm min is probably correct but I am not sure about the fronts? As best as I can work out the fronts are 34mm so maybe the same -2mm applies???
Regards
Cobra66
Old Jun 26, 2018 | 08:29 AM
J doubleU's Avatar
Minimun specifications are stamped on the rotors. Yes 2mm from new.
drspeed
Jul 24, 2014 02:43 PM
timwhayden
Sep 14, 2013 05:52 PM
vrnkc
Jun 18, 2011 07:41 AM
bsavino
Mar 26, 2009 02:51 PM
JakeMate
Jan 19, 2005 10:38 PM
