Diagnostic software for Vantage ASM
Old Sep 19, 2018 | 09:20 AM
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
I sold my vantage a while back. My friend has a ASM V8 vantage with gearbox issues and I'd like to help him with it. What software is out there for diagnostics?
Also, is the ASM Vantage just like the Italians where you need special software to perform clutch relearn, clutch PIS, clutch bleed, ASM hydraulic bleed, etc? If so, who makes good software.
Old Sep 19, 2018 | 11:04 AM
MRCW's Avatar
clutch relearn and bleeding is pretty easy and no software or diagnostics needed for that.
ASM is controlled by software that can only be updated with Aston diagnostics and it can also read rudimentary clutch wear.
My shifting improved when the software was updated...
clutches are the weak spot on these cars
Old Sep 19, 2018 | 01:57 PM
J doubleU's Avatar
What is it doing or not doing? Best thing is have the dealer check for codes and clutch life. Could be anything from a brake switch to new clutch. It's not worth the investment to get codes yourself with software.
Old Sep 20, 2018 | 08:33 AM
GMendoza's Avatar
I haven't seen the car personally yet but it sounds like it it is stuck in gear and wont go into neutral.
So only the fancy Aston software can perform diagnostics?
Old Sep 20, 2018 | 11:58 AM
J doubleU's Avatar
System codes really do not help, start with the basics. (this one is free!) No gear selection, you should make sure you have fluid and most important hyd. pump operation. If you open the drivers door (make sure vehicle battery is good) you should hear the pump come on for a few seconds 3-5.
rocketboots999
Dec 27, 2021 03:49 AM
AZV8s
Apr 29, 2020 06:33 AM
goto35
Jul 12, 2017 06:08 PM
StormDK
Jun 27, 2017 07:16 PM
dmose
Sep 18, 2014 09:34 AM
