VelocityAP Airbox Delete Kit for V8 Vantage, V12 Vantage, DB9, DBS, Vanquish, Rapide
Old Dec 5, 2018 | 06:30 PM
Irish07@VelocityAP's Avatar
Originally Posted by cadman
rich at redpants has already developed this ?whats is the the difference with the VAP one ??
Both kits are similar..
The Redpants design, from what I see in pics uses the original air filter(or OEM replacement) and requires the inlet tube from your air box. I'm just not sure how redpants keeps the filter attached to the redpants designed mount? Mainly because the stock air filter in the original airbox is sandwiched in place (top and bottom) to prevent the filter from falling off. This would really need to be explained by Rich on how the filter is secured...
Our VAP kit deletes the intake boxes completely and stock filters altogether. To guarantee the air filter won't fall off, we include a set of high flowing filters that are clamped on with a worm gear.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Dec 6, 2018 | 09:20 AM
@Kanga
I'd say that would be a good call to swap on a cone filter for the redpants bracket.
The VAP kit is a different mounting, the filter will sit higher up away from the lower part of fender liner, which also increases induction wading depth. I generally see a large amount of airboxes cracked open from lack of ground clearance, so I wanted to keep the filter up high as possible and avoid any chance of impact.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 6, 2018 | 11:32 AM
V12V's Avatar
V12V is infamous around these parts
I'm interested as well. Ken
Old Dec 6, 2018 | 01:13 PM
911MTB's Avatar
911MTB is infamous around these parts
Are there any stats on the quantifiable power gain? I'm just wondering if this upgrade is worth the investment. I'm not too worried about the increased induction noise as I enjoy the sound coming out the back of my car quite a bit
Old Dec 6, 2018 | 01:49 PM
J doubleU's Avatar
5-10HP and you never have to worry about a cracked airbox replacement. Easy to remove and refit when servicing.
Old Dec 6, 2018 | 03:03 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
If Rich had his finished before Summitt cracked my airbox I would have replaced with this option instead of the $500 for the new airbox.
Old Dec 6, 2018 | 03:30 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
Would this void my factory warranty? I'd like to get a little more sound - so this might solve that problem. Any idea of costs? Ballpark
Old Dec 6, 2018 | 04:23 PM
Your not cutting or modifying any parts, would be like adding an aftermarket loud exhaust muffler. Unbolt the entire airbox and bolt in our kit to secure the MAF tubes. The part which helps control the AFR is the MAF tubes, neither of them are being messed with, making the kit also 100% reversible.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 6, 2018 | 04:35 PM
It would be hard to give an exact figure on power, this kit is being used on a 4.3L Vantage right to a 2019 V12 6.0L Vanquish S, and then there's the option of Power Upgrade Bypass'd stock airboxs or regular airboxes...
I'd say 5-10hp is about right, could be more though...
Regardless, you should have an improved response and the more power that's created will net a fuel savings due to engine not working as hard to draw in air. I mean it's not we pay much for fuel in Canada anyways, so who cares about that part..
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 7, 2018 | 08:36 AM
911MTB's Avatar
Are the cone filters you're using oilless? Are they reusable, in other words can they be cleaned and reused like oiled filters can?
Old Dec 7, 2018 | 09:58 AM
robertwroth's Avatar
robertwroth is infamous around these parts
Group Buy
I'd also be very interested in doing this if a group buy happens.
Old Dec 7, 2018 | 11:47 AM
Filter type is not finalized yet..
If oiled, would most likely be a lifetime warranty style, so would be reusable/washable at 16-20k range. Also throwing idea around of selling just bracket if client prefer that option. We could do oilless but there's not as many options which would bump the price being fewer selection available.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 8, 2018 | 08:39 PM
Scottiejo's Avatar
Scottiejo is infamous around these parts
I'm interested. Especially if 100% reversible. I have the tune, cats, and intake filters. Clutch and flywheel arrives Tuesday!
Old Dec 9, 2018 | 01:27 AM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
I'm in
Old Dec 9, 2018 | 02:48 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Okay looks like this is a go. Just finalizing a filter option with our supplier. We used an off the shelf that's not *quite* right for this one so will be making one specifically for this application.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
