Squeaking plastic panel around rear window
Old Dec 16, 2018 | 08:51 PM
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
My 14 v8v sounds like hard styrofoam rubbing against hard styrofoam from the plastic panel surrounding the inside of the rear window. I can pull down on the piece while driving and it stops the sound. Best I’ve come up with is stuffing a shop towel in the corners, but that only seems to fix it for a few days until it’s smushed (no Longer applying pressure against the plastic piece) and the very annoying sound returns. The piece is not loose or anything, and makes the sound from both top sides.
Any suggestions?
eta: have a photo but it seems unwilling to upload from my iPhone on mobile or full site
Old Dec 27, 2018 | 05:30 PM
MikeR397's Avatar
Bump. Nobody else has a very annoying squeaking from the rear windshield interior plastic panel? I can’t make it squeak manually, but while driving I can push up or pull down on the plastic and the noise stops completely. Just can’t figure how how to make it more permanent.
Old Dec 28, 2018 | 10:04 AM
J doubleU's Avatar
? Confused with the plastic panel reference. Are you mistaking the hatch panel itself as a trim panel. Its probably just the rubber seal to hatch making noise. Gets worse when cold/dry weather. Try some silicone spray on the surface.
Old Dec 29, 2018 | 02:43 PM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
A picture of the suspected part/location would be helpful.
If the noise is plastic cover rubbing vs styrofoam, how about opening and putting a insulation layer (soft fabric, alcantara) inbetween?
Thomas
Old Dec 30, 2018 | 10:54 AM
MikeR397's Avatar
Finally got a pic to upload...See blue shop towels stuffed to temporarily prevent the noise. After a day the towels get compressed and the outward pressure stops and styrofoam squeaking resumes unless I push up or pull down on this panel while driving.
I cant get it to make the noise with the hatchback open or pushig on it myself, it only happens naturally when driving.
for all I know it may not be The panel but something else the panel puts pressure on.
Old Dec 31, 2018 | 03:30 AM
TR-Spider's Avatar
5 Year Member
Probably the squeking happens a layer deeper, i.e. between styrofoam and metal?
That could explain the effect of loosing pressure.
Old Dec 31, 2018 | 06:08 AM
handyman2009's Avatar
Veteran: Canadian Forces
I had the same issue with mine and I was able to resolve it by adding little felt pad on the hinges of the tailgate, if you look closely you will see little rubber pad, I added a little felt pad on top of it.... I look at your picture and don't see the adjuster for the tailgate on the hinges, mine is a 2009 Vantage.
North Shore 911
Feb 28, 2015 04:21 PM
msv
Feb 23, 2012 11:50 AM
cavsct94
Sep 15, 2011 11:37 AM
rvhpno80
Jan 7, 2010 06:53 AM
Shay2n10
Nov 18, 2005 08:36 PM
