Door Mirror Removal - Proper Corrosion Fix
Old Feb 7, 2019 | 07:46 PM
fallingjetengine's Avatar
fallingjetengine is infamous around these parts
Exclamation Door Mirror Removal - Proper Corrosion Fix
Here is a DIY I created to help you remove your door mirror - It's pretty involved, but a more permanent fix to the common corrosion problem we've faced. I'm very glad I did it, because once I removed the part I noticed there ware corrosion on the piece inside the door and under the quarter window - If I sanded and spray-painted it in place, as other have suggested, it would not have lasted very long.
Old Feb 8, 2019 | 04:36 AM
handyman2009's Avatar
Veteran: Canadian Forces
Thank you, very nice write up...
Old Feb 8, 2019 | 06:20 AM
W126C's Avatar
W126C is infamous around these parts
Good information to keep on hand. Thanks.
Regards,
Old Feb 11, 2019 | 01:26 PM
OnyxVantage's Avatar
OnyxVantage is infamous around these parts
Thank you for posting, excellent...
Old Feb 23, 2020 | 11:38 AM
BigMig's Avatar
BigMig is infamous around these parts
Hi
I'm just in the process of stripping down my wing mirrors, cross threaded bolts on the window channel nearly stopped me in my tracks. This handy guide is great thanks. I'm now at the point of removing the wiring terminal, but can't seem to get the wires to release despite having a range of pin tools. I'm struggling to see from your picture which side the barb is on the connector? Do you recall what approach angle was required?
Old Feb 24, 2020 | 12:12 PM
MRCW's Avatar
what are the warning signs for this situation? how can you inspect?
Old Nov 4, 2020 | 09:12 PM
uRogue's Avatar
uRogue is infamous around these parts
Hey fallingjetengine
Just a quick thanks for the brilliant "how to remove wingmirror" guide.
Managed to pick up a couple of replacement wing mirrors to swap out my corroded ones.
Was all going well until I got to the little bastard screw hiding in the window seal.
Bloody thing was stuck tight and is now head stripped/rounded. Bollocks!
Reverting to Plan B (mask, sand, prime, paint)
Ah well. Thanks anyways.
Cheers.
TSG
Sep 24, 2015 06:17 AM
ECS Tuning - BMW
BMW Vendor Classifieds
Feb 10, 2014 10:14 AM
