Heavily modified V8 Vantage at full throttle.
Old Feb 10, 2019 | 01:09 AM
bolteon's Avatar
5 Year Member
bolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud of
Car sounds nice but heavily modified and bolt ons are not the same thing.
Old Feb 10, 2019 | 08:38 AM
DetomasoGTS74's Avatar
Originally Posted by FR500GT
Damn that is quite the mod list! What seats are you going to run? Any pictures of your car?
Cobra Nogaros
Old Feb 10, 2019 | 08:40 AM
Originally Posted by handyman2009
DetomasoGTS74, what tire size are you running on this beast...
They are 305/25/20 and 255/30/20
Originally Posted by Montana107
Beautiful Car and Excellent Build! Well Done DetomasoGTS74
Thanks Scott- appreciated your guidance on the suspension setup, hope all is well!
Old Feb 10, 2019 | 08:52 AM
Originally Posted by spinecho
Sounds suitably nasty. Any run past clips from outside?
Thanks! No clips I have taken from the outside. Only clips are from the BlackVue inside the car.
only clip I know of taken of the car from the outside is this one. Start at 6:30 in.
Old Feb 10, 2019 | 09:06 AM
Given the sum of the (bolt on) parts I have put in is worth more than the car would be sans parts, it is to me! That said I have seen the Texas mile cars and do know where you are going, but this is an Aston. Not a GTR, or a Mustang, or an UGR Huracan for which "heavily" means something entirely different.
Balancing keeping the timeless looks while improving upon almost every component (OEM+) to make it what it should have been from the factory performance wise has been my goal. Purchashing essentially every upgradable OEM+ component available has been the long (and fun) build process!
Old Feb 11, 2019 | 02:07 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
and what size are the rims compared with stock? best looking rims ive seen on the AMV8
Old Feb 15, 2019 | 07:06 PM
Went one inch larger (20) vs stock. I feel 20" fills out the fender the best, and with an aggressive offset it pushes out the fender to really accentuate the curves of the car. Especially in the original, pure design before they messed with the sills.
That said I have also kept the stock sport pack 5 spoke wheels for the track (never happens)
Old Feb 16, 2019 | 06:14 PM
Ghosty's Avatar
Ghosty is infamous around these parts
Detomaso, she sounds badass! Sorry if I missed it earlier, but what year V8V? What else besides seats netted you the 200# weight reduction? Was the QS exhaust a big weight savings? Ever dyno it before/after the ECU tune? Does your twin-disk clutch chatter very much? Rated for much more torque than the stocker?
Side-note, do you also have (or had) a Pantera? Hahaa.
Old Feb 17, 2019 | 07:36 AM
wheels -27.2 lbs
battery -42 lbs
muffler -27.0 lbs
high-flow cats -8 lbs
headers -8.25 lbs
cargo divider -10 lbs (estimate, only when at the track)
VelocityAP clutch and lightweight flywheel -17.5lbs
Aston Martin N420 rear diffuser -2.5lbs
Air box delete -8lbs
Nitron coilovers -11.6lbs
Current -162.05lbs
Still to do:
2 piece Wilwood rotors -18lbs
Cobra Nogaros -50lbs
Grand total of
230.05lbs
Its a 2006, no dyno for tune alone, Velocity AP custom tuned for half day following all mods. Twin disk does chatter at idle a bit, they bumped idle to 950 to eliminate 95% of it...much more torque, it’s OEM for V12.
I grew up working under my dad’s DeTomaso Pantera GTS with him that he bought new in 1973 (74 model year). Car has just under 30,000 original miles and is one of perhaps 50 true GTS’s in the states. It’s the car that got me into cars and the one thing that will be left for me someday. Took the below pictures when visiting them in TN last year.
DetomasoGTS74
Feb 8, 2019 12:46 PM
CadenceX
Aug 1, 2006 07:13 PM
iLLM3
Dec 5, 2005 05:51 PM
iLLM3
Oct 26, 2005 02:22 PM
iLLM3
Sep 27, 2005 01:52 PM
