4.7 oil change clarification
Old Apr 9, 2019 | 08:33 AM
yidal8's Avatar
yidal8 is infamous around these parts
I know the 4.3 has the front/rear bypass filters that need to be removed during an oil change, in addition to the oil tank and filter. Does the 4.7 has same 2 bypass filters to deal with?
Thanks.
Old Apr 9, 2019 | 10:25 AM
lilseevs's Avatar
lilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud of
You do not need to worry about bypass filters on the 4.7l
https://www.redpants.lol/oil-change
Old Apr 13, 2019 | 05:09 AM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
Thanks.
There’s actually 5 locations to drain oil on the 4.3:
1. Oil reservoir. 13 mm on the hand welded tank that houses the dipstick
2. Oil sump. 13 mm underneath engine near forward bypass filter
3. Forward bypass filter Torx T-30
4. Rearward bypass filter Torx T-30
5. Oil filter
excluding bypass filters that that still leaves 3 locations on the 4.7.
sanengo
Jan 16, 2016 10:29 AM
ale70
Jun 15, 2013 02:31 PM
theoilman
Apr 20, 2012 09:58 AM
og risker
Sep 1, 2010 01:49 AM
pgunz
Feb 25, 2009 04:44 PM
