'06 db9
Old Jun 16, 2019 | 07:08 AM
Shooter Martin's Avatar
Shooter Martin is infamous around these parts
'06 db9
Hello, I own a 2006 Aston Martin DB9 and the doors raise up about 15 degrees when you open them (so as not to hit a curb) and was wondering if there was an adjustment on them to increase the tension on the spring because when the car is slightly inclined the door will not stay open ?
Thank you,
TK
Old Jun 16, 2019 | 07:29 AM
J doubleU's Avatar
Common wear item that needs replaced. You should have not only the doors, but hood and trunk gas assist struts replaced at the same time. Quick search on here found this....
https://www.6speedonline.com/forums/...placement.html
Old Jun 16, 2019 | 08:03 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Strut replacements
Here's another link with additional information;
gtmule
May 6, 2021 07:42 PM
CarPoint
May 14, 2013 01:28 AM
donahdi
Jun 28, 2010 04:33 PM
Chordate
Mar 18, 2004 01:47 PM
