Mild to wild exhaust remotes. What are you guys using?
Old Jun 16, 2019 | 10:19 AM
Ozzir's Avatar
Ozzir is infamous around these parts
Just wondering what you guys are using to control the exhaust valves on your Vantages? I’ve read about the mild to wild on Vettes but they don’t list the Vantage on their website. Do these work on the Vantage? What options are out there?
Old Jun 16, 2019 | 11:07 AM
Teekster's Avatar
Teekster is infamous around these partsTeekster is infamous around these parts
Works fine on a vantage
Old Jun 16, 2019 | 11:25 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Search this forum for fuse 22 (or fuse 15 for more recent models)
Old Jun 16, 2019 | 02:32 PM
smdzucladoc's Avatar
smdzucladoc is infamous around these parts
Buy a remote control relay kit and connect to whatever fuse your car uses (15/22). You can then use the remote to either have always open or OEM control. I programmed my garage door opener to the remote so I can turn on and off without the remote at all.
This is the one I use in my car. $18
Logisys RM02 Logisys RM02
Old Jun 17, 2019 | 03:32 AM
cadman's Avatar
5 Year Member
cadman is a jewel in the roughcadman is a jewel in the roughcadman is a jewel in the rough
i have the remote from clive on pistonheads in the u.k 5 minute install,
https://www.cccharger.co.uk/
Old Jun 17, 2019 | 05:03 AM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
Yes, I have his Jaguar variant on my F-Type.
Old Jun 17, 2019 | 08:27 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Forum Search Useful
Quite a lengthy earlier post on the subject; Post #43 onwards regarding the inexpensive option.
https://www.6speedonline.com/forums/...-switch-3.html
FYI, I have one of the homelink buttons programed to go back to factory mode.
Old Jun 17, 2019 | 10:24 AM
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
Logisys RM02
I use the same Logisys RM02. Works great. Default with this is to keep the valves open, so they'll be open when you start the car and you can choose to close them.
Old Jun 19, 2019 | 08:02 AM
plastique999's Avatar
plastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to all
I have a Capristo remote on my Speciale...something similar should work
Old Jun 19, 2019 | 11:40 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I have this one as well and it's highly recommended for Aston's. I believe he's sold over 600 of them. Easy install.
My service manager at local AM dealer says they've seen error codes when the fuse is taken out. I did that on the Vantage and did not get an error code, but not being able to switch from loud to normal is a big deal. I don't need it so loud when settled into hwy driving.
andreas
Lamborghini
Mar 19, 2006 06:40 PM
TT
Cayenne 955/957
Nov 9, 2005 04:56 PM
DJ
Cayenne 955/957
Apr 7, 2005 11:13 AM
