DB9 "Boot Open" Error
Old Jun 18, 2019 | 09:40 AM
Calcifer33's Avatar
Calcifer33 is infamous around these parts
Hi everyone, new DB9 owner here. My 2005 DB9 sometimes gives me a "Boot Open" error even though the boot is closed. I checked and when it's closed, there doesn't seem to be any remaining play in the boot top (it doesn't rattle or move). What should I adjust or fix to remedy this issue?
Car has only 5700k miles on it, though I don't expect that matters.
Old Jun 18, 2019 | 01:53 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I had an intermittent false "Trunk Open" message for a couple of months. Replaced the trunk latch assembly (6G33-31253052-AA) and haven't had a problem since.
It's a fairly easy DIY and the part is about $100 USD delivered from the UK.
There's nothing to adjust, so it's most likely a failing microswitch/sensor.
Old Jun 18, 2019 | 01:55 PM
Calcifer33's Avatar
Thanks! I did a search before buying the car and someone said there was an adjustment to make, but no matter how much I search I can't seem to find that thread anymore. Anyone know if there are any adjustments before I go replacing the latch assembly?
Old Jun 18, 2019 | 02:32 PM
yvr's Avatar
yvr
Here's on old thread with no resolution reported: https://www.6speedonline.com/forums/...n-warning.html
Having had it apart I'm pretty sure there's no adjustment possible, unless you're going to make up shims or something.
The assembly bolts into place with very little play.
Old Jun 20, 2019 | 11:51 AM
yvr's Avatar
yvr
Old Jun 20, 2019 | 11:55 AM
Calcifer33's Avatar
Thank you! I'll have to take apart everything to give it all a good look.
zuman
Oct 30, 2016 09:30 AM
corveight
Feb 11, 2015 04:16 AM
dhahlen
May 3, 2014 06:02 PM
merosenb
Nov 11, 2012 06:58 AM
///amgny
Jul 25, 2012 11:35 PM
