2014 Rapide S - Battery Replacement / Rear headrest latch
Old Apr 28, 2020 | 09:27 AM
Irish07@VelocityAP's Avatar
Originally Posted by silanarchy
When you say disconnect the ground for 45 secs do you mean the negative terminal? Apologies for the silly question in advance, just want to make sure before i pull the seat out to get to it.
Yes, negative terminal.
​​​​​​​Being it's a hard reset, there's no need to disconnect the positive terminal...
The Negative (aka ground) is always disconnected first in DC voltage circuits. This avoids any chance of arcing with chassis..
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old May 1, 2020 | 12:31 AM
silanarchy's Avatar
silanarchy is infamous around these parts
​​​​​​​Thanks for that, did the window reset on all windows straight after the battery disconnect and everythings fine, door now closes properly. Your a legend cheers pal.
Old Nov 19, 2023 | 10:19 AM
zzzamdb9's Avatar
5 Year Member
zzzamdb9 is infamous around these parts
I’m having the same issue as you. My rear passenger headrest is not latching, the seat release button is lit up and my cord is not retracting. How did you take the seat apart to get the cord to go back in? I’ve tried tugging it numerous times from different angles and it’s not retracting. Thanks!
Originally Posted by BigSkidRowe
Took the seat apart again - what I thought was missing slack, was exactly what you thought - the cord was stuck under a trim element holding the release open. Sharp tug in another direction and the release....released. Headrest latch works.
Old Nov 25, 2023 | 10:21 AM
zzzamdb9's Avatar
5 Year Member
I took off the bottom seat cushion and was able to realign the manual release cord which fixed the latching.
NJ99
Cayenne 955/957
Apr 27, 2019 11:36 PM
Nixer
Cayenne 958
44
May 26, 2016 05:42 PM
darren08
Jan 6, 2015 10:33 AM
whitep4
May 12, 2012 03:31 PM
simrohor
Nov 12, 2009 05:40 PM
