Key/Ignition Problem
Old Sep 20, 2019 | 08:54 AM
thisistcab7's Avatar
thisistcab7 is infamous around these parts
I’ve owned my 2013 V8V (With Sportshift) for 2 weeks now. At first I thought I just didn’t know what I was doing... But I am pretty sure this is not normal!
I have to push the key in and out 5x before the electrics will catch and unless I push the ECU in as SLOW as possible it won’t fire the engine.
I have tried with the break pedal depressed and it doesn’t work as good as if I don’t touch the break until I hear the engine trying to crank.
Last night I thought I was stranded. Tried the starting procedure 20-30x before it finally worked.
The electrics don’t even start up at all unless I seem to push the key at just the right angle.
The glass key locks/unlocks the car perfectly. But I can’t even start the car with it. Only the Valet key works for ingnition.
Any insight?
Old Sep 20, 2019 | 12:04 PM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
I had a similar issue with my 2012 V12.... had to replace the ignition module
Old Sep 20, 2019 | 02:47 PM
Graze's Avatar
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
AM have a replacement ignition module on order for my V12 also, for the same issue
Graeme
Old Sep 20, 2019 | 06:46 PM
Have either of you got to the point where it would not start at all?
Im hoping not to get stranded!
Old Sep 20, 2019 | 07:47 PM
XJRS Owner's Avatar
Make sure you have foot on the brake, N selected, then two flat finger push to flush position, then red light should illuminate. Then final push to start position and release. If you don't see a red light, either you aren't doing it right, or it could be a bad module.
Old Sep 21, 2019 | 07:06 AM
Bones 53's Avatar
5 Year Member
I never got stranded..however it was getting progressively worse...I knew there was an issue that needed attention.
JH
Old Sep 21, 2019 | 07:26 AM
Graze's Avatar
Never stranded but mine isn't as bad as you describe. Happens maybe 1 time in 3 or 4 that it won't start
hope u get it sorted
Graze
dcarrer0
Jun 26, 2019 07:53 PM
EZ Cookin
Feb 1, 2017 02:23 PM
captain Greg
May 24, 2016 07:33 PM
SeattleBum
Cayenne 955/957
14
Aug 11, 2011 10:23 PM
csm356
Dec 10, 2010 09:05 AM
