Red Line gear oil differences?
Old Nov 18, 2019 | 12:53 PM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
I posted this in the gear oil sticky thread but haven't gotten an answer:
I've heard people recommend Red Line MT-LV 70W-75 GL-4 gear oil. I'm wondering what the major differences are between that and Red Line MTL 75W-80 GL-4 (which can be as much as $20 less expensive per gallon) for the manual 6-speed cars.
Does the MT-LV have some additive that the MTL lacks?
Old Nov 18, 2019 | 01:33 PM
J doubleU's Avatar
For $20 you can select 2nd gear when cold. AM recommends a 70w oil for that reason. Just use the MT-LV 70W-75 GL-4
Old Nov 18, 2019 | 01:55 PM
Kalepsis's Avatar
5 Year Member
Sound advice. I'll take it.
Oddly, I never have a problem upshifting to 2nd, even when cold. Downshifting to 1st, though, is another story entirely.
Old Nov 18, 2019 | 03:36 PM
voodoocat's Avatar
voodoocat is infamous around these parts
MT-LV specifically state compatibility with BOT270A Graziano transmission and mention Aston Martin by name.
Old Nov 19, 2019 | 09:47 AM
papigko's Avatar
papigko is a glorious beacon of lightpapigko is a glorious beacon of lightpapigko is a glorious beacon of lightpapigko is a glorious beacon of lightpapigko is a glorious beacon of light
I don't know where your are but I've clearly had first to second shift grinding on days below 10*F outside and the car in my unheated garage, but usually only my first shift of the morning after leaving my driveway but still worth the extra $ in my opinion. Since I changed I have not had a problem. The 75w80 was clearly better than the redline 75w90 but also clearly not as good as the bot or the 70w75
Old Apr 17, 2024 | 07:36 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
old thread but does the MT-LV require the Kendal additive?
Old Apr 18, 2024 | 01:08 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
I used the Red Line and have had no problems. Red Line says it is made for Graziano gear boxes.
Old Apr 21, 2024 | 09:56 PM
right...but the question was does the MT-LV require the Kendal additive? i read another post from VAP that indicates Kendal additive is not needed in Vantage Graziano gearbox at all
911MTB
Canada
Apr 3, 2019 07:23 AM
the_vetman
Apr 25, 2016 09:07 PM
TdiRacing
Feb 22, 2010 09:06 PM
REELDEEP
Oct 14, 2009 05:08 AM
Gundo
Nov 4, 2007 10:50 PM
