Winter Storage Question
Old Dec 27, 2019 | 09:25 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
In the past, when I store my Vantages in the winter, I would run them a few minutes from time to time when I cold pull the car out into the alley and run it. Last year I did not do that because it's unlikely to get warm in Minnesota winters just idling a few minutes.
What's worse - not running the engine at all for 4 to 5 months, or on occasion starting it and letting it run say 5 minutes every month or so?
Old Dec 27, 2019 | 09:56 AM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
it never gets to operating temp while idling. Causes unnecessary condensation in oil, exhaust, plus more wear with cold winter start ups. Unless can drive for 20 mins to operating temp, let it sit. If stored properly, letting it sit several months, is not a big deal, imo.
Old Dec 27, 2019 | 10:12 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Theoretically you don't want to run the engine for Short periods because the moisture in the oil doesn't get burned off. That moisture can both corrode internal parts and contribute to oil acidity. However, I've seen a couple of people do used oil analysis on cars that were used for very low mileage and started and stopped and the oil looked fine. On the other hand, I have a generator that self checks by running every Saturday for five minutes. After 6 months the oil looks like a chocolate milk shake from all the water in it.
I don't start my engine over the winter but I do turn it over a couple times with the gas pedal on the floor over the storage time to make sure the cylinder walls and bearings have a coat of oil on them.
Old Dec 27, 2019 | 11:58 AM
Prefurbia's Avatar
Does the turn over with the pedal to the floor work with the V12S as it does with the V8's?
Old Dec 27, 2019 | 07:50 PM
blue2000s's Avatar
I know the older DB's had it. Check in your manual under "Storing your Vehicle"
Old Dec 27, 2019 | 11:26 PM
MBi's Avatar
MBi
MBi is infamous around these parts
Don't forget a battery tender while it's sitting and your tires pressures.
Old Dec 28, 2019 | 09:43 AM
Prefurbia's Avatar
Does not mention such procedure in my V12S manual
Old Dec 28, 2019 | 02:38 PM
blue2000s's Avatar
This is what is in the DB manual.
You could always just try it. I suspect you're not going anywhere today, it's kinda Icy
Old Dec 28, 2019 | 03:45 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Ford ECU does this trick on older cars. Newer V12s with Bosch ECU (including V12S) will start at full throttle.
Old Dec 28, 2019 | 05:17 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Agree with all stated above, and I have posted on this subject on this forum, in the past.
The last thing you want to do is start your car from storage and idle it for a few minutes. Just let it be until the spring.
As noted, the S with Bosch ECU no longer has the spark inhibit function. Such a shame... I cringe every spring when starting mine up for the first time, as must anyone with an ounce of mechanical sympathy. Why more high end cars aren't fitted with this feature is beyond me, since a lot of customers must be storing them for extended periods in many parts of the world they are sold.
Old Dec 29, 2019 | 01:12 PM
JL_MPLS's Avatar
JL_MPLS is infamous around these parts
For cars without the start-up suspend feature, pull the fuse for the fuel pump before you engage the starter and the car won't start. Crank it over until you get oil pressure and then put the fuse back in.
Totally agree with advice to let the cars sit over the winter. I usually inflate tires to 60 PSI to avoid flat spotting but my OEM tires have cracks so they're being replaced this spring. No need to protect them over the winter.
Old Dec 30, 2019 | 06:42 AM
Prefurbia's Avatar
Thanks! I checked the owners manual, and mine does not have the step 4 - puling fuel pump fuse is a great idea!
Old Dec 30, 2019 | 06:54 AM
MRCW's Avatar
move to Florida!
Old Dec 30, 2019 | 07:16 AM
Prefurbia's Avatar
Working on it, right now we have a 3,600 sq.ft. home overlooking 5 acres of woods/wetland in St. Louis Park,MN no next door neighbors, a dual certified 'green' home with a 4 car garage, elevator, 5 bedrooms 4 baths, and every window and room coordinated with a view of open space - right in a dense urban setting! Winter utility bills are $50 a month, Craftsman with metal roof, with a modern flair, a home too large for us and a mortgage I'd like to retire - trying to convince my wife to sell our home this spring, take the $600K to 700K equity (we owe $500K), buy or more likely build a nice smaller home somewhat near the Ocean, perhaps Charleston or North Carolina - pay cash and still have $300+K in the bank. I designed Trasona at Viera, Florida that I'd love to live in, but mid-Florida gets a lot of rain, and traffic at Viera, especially rush hour around the 'roundabouts' is terrible. But Trasona is an incredible neighborhood (each home and lot shape of the 1,350 homes to be built there has the floor plan coordinated with the surrounding views) and the meandering setbacks streets and walks is like living in a piece of elegant modern art. But I'm on the fence about Florida vs. Charleston. I also have to travel a bit (about twice a month), so being by an international airport is handy (Trasona is 45 minutes from Orlando).
So thinking about it seriously.
ohTHATeric
Sep 27, 2014 11:41 AM
TAZ40JAHRE
Mar 5, 2014 10:17 AM
gretapass
Sep 10, 2008 08:34 AM
NYSpeedRacer84
Dec 31, 2007 12:18 PM
btromp
Dec 8, 2007 04:55 PM
