DB9 Airbag Warning
Old Dec 30, 2019 | 07:19 AM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
DB9 Airbag Warning
Fired up my '05 DB9 this morning and was greeted by "SRS Airbag Service Urgent" on the display. The airbag light was lit on the dash as well. I've had similar warnings on other cars that went away relatively quick. Is this truly urgent on AMs?
Old Dec 30, 2019 | 10:30 AM
bobdisp's Avatar
5 Year Member
I'm getting a P0055 code on my scanner.
Old Dec 30, 2019 | 03:14 PM
bobdisp's Avatar
5 Year Member
It reads "Squib left side airbag (seat mounted) resistance too high".
Old Dec 30, 2019 | 03:40 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Sounds like you have an open circuit on that airbag. Could be in the detonator, or just a loose connection. Good news is that it won't fire on an open circuit.
Old Dec 30, 2019 | 04:34 PM
bobdisp's Avatar
5 Year Member
If that is the case AM4884, what is the fix? I want my normal display back!!
And Matt- satisfied customer here on my jacking pads.
Old Dec 31, 2019 | 06:48 AM
bobdisp's Avatar
5 Year Member
That was fun Matt. My favorite thing to do with my morning coffee is dive into tight spots and reverse engineer a British made plug so I can disconnect it. Unfortunately it did not correct the error. It looks like a trip to my AM dealership is in my future.
Old Jan 22, 2020 | 08:11 AM
bobdisp's Avatar
5 Year Member
I downloaded an update to my scanner and was able to clear fault. My Foxwell scanner just paid for itself!!
Old Jan 22, 2020 | 10:01 AM
bobdisp's Avatar
5 Year Member
NT510 purchased in 2017.
Old Jan 23, 2020 | 06:22 PM
sliderule01's Avatar
sliderule01 is infamous around these parts
I have the NT520 and it works well.
Old Jan 23, 2020 | 07:02 PM
I have the exact same fault, and have not been able to clear it either. I talked with Jon at Steel Wings, and he said it can wait. I will have them look at it when I take it there for oil change and annual check up.
In the manual they indicate that the issue may be something under the seats or similar. Mine occurred when I lifted my laptop on the seat when I was driving home.
Old Jan 24, 2020 | 08:19 AM
XJRS Owner's Avatar
Presumably you are using the correct port on the car? SRS can only be cleared through the body port (if the fault or problem has been rectified).
Old Jan 24, 2020 | 10:02 AM
Correct port - the SRS was cleared by the scanner. HOWEVER, the warning that does not clear is "Passenger Airbag Service Required". This will not clear.
Old Jul 2, 2022 | 02:05 PM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
Was there ever a resolution to this?
I'm getting a spurious P002B which the Foxwell NT530 (incorrectly maps) to "Squib Load Adaptive Steering Column" "resistance too high", but on my Rapide , it's actually "Squib rear DMIC (in door) airbag right" "resistance too high" .
I seem to have triggered it after a low battery crank (where I got about 40 DTCs and was able to clear all of them except this one)
I've tested the "door mounted integrated curtain" airbag resistance directly in the door (vs a spare unit) with a test plug I made and it's within spec of eachother. I can clear the code and it either comes back immediately, or takes a couple days to come back. Unfortunately, the Foxwell NT530 appears to not have very good Rapide support as I'm unable to monitor the rear doors (surprise!) airbag resistance in the live data, which would be a big help.
Next step is to check the resistance across from the RCM plug to the door module, but interested to know if anyone's cleared a "squib resistance too high" error, or if it's likely a RCM unit that was damaged during the low voltage event I had.
Old Jul 5, 2022 | 04:45 PM
bobdisp's Avatar
5 Year Member
Yes three was resolution. I cleared it with my scanner and it hasn't surfaced since. Good luck with the gremlin search....
broncoupe
Nov 8, 2021 07:08 AM
sliderule01
Oct 30, 2019 04:21 PM
sliderule01
Aug 23, 2019 06:42 AM
André CHARLES
May 5, 2019 12:59 AM
LIDB9
Aug 22, 2016 05:50 PM
