Coil Pack 2007 DB9
Old Feb 10, 2020 | 05:33 PM
sliderule01's Avatar
sliderule01 is infamous around these parts
Coil Pack 2007 DB9
Are the coil packs for the DB9 the same as the Ford 3.0L V6 x2? As I recall, they are DG-213. Are these the correct coil packs? $200 for 6
Old Feb 12, 2020 | 11:23 AM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Hi Scott,
I poked around quite a bit but could never find a 3 pin coil pack. A 2007 should have the 3 pin and not the more common 2 pin. This allows them to run individual ground lines to each coil. Are these 3 pin?
Best
Larry
Old Feb 12, 2020 | 12:46 PM
I am pretty sure they are 3 pin based on other articles like this one from Aston Martin 1936. Some of the comments indicate that the Jaguar 3.0 fit. Going through auto parts places, they indicate the Motorcraft DG-213 is a replacement, but before I buy any, I want to make sure
Old Feb 12, 2020 | 03:23 PM
AM4884's Avatar
5 Year Member
What Steve shows is a 2 pin coilover. I never found a 3 pin...
Old Feb 12, 2020 | 05:50 PM
07sportspack's Avatar
07sportspack is infamous around these parts
My 2007 are 3 pin. My understanding is that 2 pin in 2007 is rare and may be in the very early 07MY.
Old Feb 12, 2020 | 05:56 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
My Feb '06 build (vin ending 5514) has 3 pin coil packs.
Old Feb 12, 2020 | 06:39 PM
The 2 pin are a Ford DG-528 (I think). I have seen several that look real possible using the 8G43-12A366-AA (3 pin) part number - specifically the 12A366-AA part of the part number - lots of Chinese manufacturers. Even found the specifc part number for $4.91 US
Old Feb 12, 2020 | 09:35 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
Other than the fuss of fitting new connectors is there a reason why one couldn't just retrofit the more common 2pin type coil? One wire is power and the other is signal. Why is there a need for a full time dedicated ground?
Old Feb 14, 2020 | 03:54 PM
AM4884's Avatar
5 Year Member
I believe AM went to a three pin to get a better ground at the coil than they would get through the block. I thought about rewiring my harness when I had it out but thought I would just let it go at this time... Something to consider in the future!
But, I absolutely refuse to believe it is a custom run of coils. It's used in something... Just need to find it!
broncoupe
Nov 8, 2021 07:08 AM
gtmule
May 6, 2021 07:42 PM
sliderule01
Sep 3, 2019 06:42 AM
André CHARLES
May 5, 2019 12:59 AM
All Mack
Apr 24, 2017 01:50 PM
