vantage brake pad sensors... cross reference or OEM?
Old Mar 11, 2020 | 09:08 AM
MRCW's Avatar
getting ready to replace brake pads... any cross referenced sensors or OEM?
does anyone simply not replace? can you just disconnect?
Old Mar 11, 2020 | 09:27 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
If you remove them carefully they can be reused. I've had a spare set sitting in a drawer for years now, but still haven't needed them after multiple pad changes.
Old Mar 11, 2020 | 02:28 PM
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
If you remove them carefully *and they haven't already tripped* you can reuse them.
You can't leave them disconnected (you'll get a constant brake alert if you do), but if you have working sensors, you can zip-tie them out of the way. I'd only recommend this if you monitor your brake pad life on your own (I do frequent track days that I swap pads for, so I always know how my pads are doing and therefore have left the sensors off the pads).
Old Mar 11, 2020 | 02:35 PM
MRCW's Avatar
sensors have not gone off... just wanted to have some on hand but can always disconnect and just wire the two sensor conductors together to cancel the warning...
I think I found some generics for under $25 instead of dealer cost...
Old Mar 11, 2020 | 02:40 PM
NiceAst's Avatar
NiceAst is infamous around these parts
You can just unplug them and jump the pins together on the harness plug to eliminate the warning.
Old Mar 11, 2020 | 03:05 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
Hi...I wire tied mine up two years ago when I changed to using the Brembo Brake pads. As long as the sensors have not been set off...not an issue.
But as warned check your pads regularly so not to harm the rotor...
Safe driving...
Old Mar 12, 2020 | 08:46 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
I believe Rock Auto has them around $25.
Old Mar 13, 2020 | 08:43 AM
MRCW's Avatar
thanks... does anyone knows if you need one for each corner or one for each axle?
Old Mar 13, 2020 | 09:48 AM
NiceAst's Avatar
It's one per wheel.
Old Mar 13, 2020 | 10:58 AM
MRCW's Avatar
Originally Posted by NiceAst
It's one per wheel.
great! thanks
Old Mar 13, 2020 | 01:25 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Originally Posted by MRCW
great! thanks
You might consider cleaning with brake cleaner and carefully remove with needle nose pliers to avoid cracking the sensor.
Chris P
Oct 9, 2018 08:00 PM
timwhayden
Sep 14, 2013 05:52 PM
rich rogers
Jan 7, 2012 06:29 PM
Project911
Oct 31, 2009 12:29 AM
