Troubleshooting tail and headlight failures?
Old Jun 4, 2020 | 01:28 PM
MrRobot's Avatar
MrRobot is infamous around these parts
I was an idiot and left my car under a car cover for too long outdoors. The car sat soaked for a couple weeks. When starting it up again, one tail light and the strip of lights in one headlight don't work.
Does anyone know if there's anything I can try before replacing these? I want to avoid ordering replacements if there is some fuse that could be causing this. Or perhaps they can be pulled out and properly dried?
The really annoying thing is the taillights are smoked, so will have to figure out how to match that exactly. If anyone has tips for that, I'd love to hear it as well.
Thanks!
Old Jun 4, 2020 | 02:00 PM
bavarianstance's Avatar
5 Year Member
bavarianstance is infamous around these partsbavarianstance is infamous around these parts
Failure of head/tail lamps due to condensation is common. There is no easy fix except to replace the entire unit I'm afraid. You can attempt to bake open the lamps and dry them out and potentially salvage them, but your results may vary.
Old Jun 4, 2020 | 02:14 PM
5 Year Member
Originally Posted by hsm precision
It's probably the PCB that drives the LEDs. I had this fail on the taillights, and was not able to fix the PCB. There isn't a separate fuse for these, so that isn't a factor.
The only real bulb is the reverse light - that is a normal bulb but still sealed inside the lights. (so 1.50 bulb that scraps out a 1500$ light...)
There were some postings in the past about fixing the front LED circuits (was due to broken capacitor or inductor - I don't recall which)
Matt
yep. here you go.
https://www.6speedonline.com/forums/...-signal-3.html
Ron Kuskie
911
Oct 23, 2014 01:39 AM
maverick997
Apr 30, 2014 05:06 PM
PrecisionPorsch
Oct 26, 2012 11:52 AM
dtran023
Cayenne 955/957
Oct 20, 2009 10:34 AM
Michael2364
Detailing
Sep 21, 2008 10:12 PM
