2009 Vantage Coupe - Second Key
Old Jun 7, 2021 | 01:23 PM
Ashman_E's Avatar
Ashman_E has a spectacular aura aboutAshman_E has a spectacular aura about
Originally Posted by 61mga
my understanding is that the PROCEDURE to duplicate a key requires two functioning keys. i.e. one functioning key is inserted (then something must be done), then, after the first key is removed, a second functioning key is inserted (and something again must be done) then, after the second key is removed, a 3rd key, the one that needs to be programmed, is inserted and (again after something is done) is programmed by the computer. ergo, no dealer is involved. i assume this can be repeated ad infinitum.
...but if you don't have a second functioning key, you've got to go to "the man".
Note that from everything I've seen and know about the electronics in this car (experts feel free to chime in on whether I'm correct), this procedure only gives you a key that will start the car. The buttons on the key still won't unlock your doors, pop your trunk, etc.
The starting of the car and the unlocking of the doors/trunk are two totally separate systems. The starting of the car is passive and all of the powered electronics are in the car. This system sends out a radio signal that the little self-contained RFID chip in the fob sees and then it sends its ID back. This is similar to the key cards you get in many hotels or that are used in many secure office buildings where you hold the card against a panel on the door lock. Same mechanism, just adapted to use in a car. In this case, if the system reads the first key and accepts it as good then reads the second key and accepts that as well, then it's put into a programming mode where the next key it reads is added to the internal list of acceptable keys for starting the car. So you CAN create a new key to start your car with two already programmed keys.
However, the unlocking of doors, etc. is what the circuit board with batteries is for in the key. When you push a button on the fob, that system sends a radio signal from the fob to the door lock system in the car which is constantly listening for a signal when the car is off. This is the way pretty much every traditional car key fob works, but this system needs to be programmed with an appropriate AMDS computer hooked up to the in-car door & window ECU.
So, if you have a new key that you want programmed to both start your car AND open your doors and trunk, then you're paying the dealer or some other garage with the appropriate hardware to do the programming. Sucks, but that's about the size of it. I just wish there were more independent garages with the AMDS computer system to properly service them here in the US. The dealers might not be charging highway robbery prices if they had a little more competition.
Old Jun 7, 2021 | 03:20 PM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
Originally Posted by Aadil
I got my shell from these guys, i must say it looks way better than the factory volvo fob
https://www.spinstatedesign.com/
The ones I'm working on will be replacements for the 09-17 model year ECUs, not the fobs for the older cars that require a turn key in the ignition. But thanks for the link, I'll keep them in mind if I ever buy an 05-08 DB9 or Vantage.
Old Jun 8, 2021 | 06:46 AM
Ashman_E's Avatar
For those that want to fully program keys, this is new and looks promising...
It looks like the Chinese are starting to come through for us on reverse engineering how these ECUs work.
I plan to eventually get one and see how it does as I have a spare valet key that I was able to program to start my car with the other two keys, but which doesn't unlock my doors.
Old Jun 8, 2021 | 09:33 AM
MRCW's Avatar
wouldn't mind a Chinese knock off of the cheap plastic ECU key... even used ones are a couple hundred $$.
Old Jan 17, 2023 | 05:25 AM
Pangerz's Avatar
5 Year Member
Pangerz is infamous around these parts
Aston Martin DB9 Key FOB programming
Reviving old thread here but has anyone tried this? I'm in the only have one key boat and wondering if any similar jaguar key with a transponder can be cut and programmed just for safety to have a backup!
Old Jan 19, 2023 | 04:29 AM
handyman2009's Avatar
Veteran: Canadian Forces
my plastic key for my 2009 Vantage cost me about $350 cdn + $75 to program at the dealership, so not the end of the world
Old Jan 24, 2023 | 05:58 PM
Pangerz's Avatar
5 Year Member
Wow the dealer here in Vegas is a different story. $250 for the key and $375 to program. Oof.
Old Jan 29, 2023 | 03:10 PM
Pangerz's Avatar
5 Year Member
In case anyone is in need of a spare ignition key just for safety:
Call up a local automotive key cutter. It's a Jag key with a 4D60 transponder in it. My local guy just copied the transponder in my existing key so I now have a working spare Incase I ever lose it. It's not a pretty Aston key but it starts the car and nice to have a backup.
Cost me $265
Old Jan 4, 2026 | 07:50 AM
uvamon's Avatar
uvamon
Hello
Just came back from dealership in South Florida also have 2009 V8 vantage. They wanted around $4000 for new key and programming. I guess these is because of new tariffs?
How did you solve?
Old Jan 4, 2026 | 07:53 AM
uvamon's Avatar
uvamon
New key
How did you solve?
For $4000 it must have been a Cristal key and not a plastic valet key. Mine was the valet key, if you search the forum for Key programming I believe that some people had good success doing it themselves
Old Jan 4, 2026 | 01:39 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
How did you solve?
$4,000 for a new key?? Are they still high from NYE?
Old Jan 4, 2026 | 01:54 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I bought the think diag..no luck as yet programming my fob..still trying…has got very frustrating…
Old Jan 4, 2026 | 02:40 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
@Import I've successfully done it with my Launch X431 scan tool on 2 different Astons. Remind me to bring it next time we meet.
Old Jan 4, 2026 | 02:44 PM
Import's Avatar
That is very kind..and absolutely will do that…thanks..and happy new year…you doing van dusen if it happens?
Thom Morrow
Oct 10, 2019 07:37 AM
goto35
Feb 13, 2016 09:52 AM
cadman
Oct 20, 2015 07:49 AM
duo
Jun 5, 2011 04:09 PM
noekult
May 17, 2009 10:37 AM
