need help with mounts
Old Sep 4, 2020 | 08:04 PM
Abdullah37's Avatar
Abdullah37 is infamous around these parts
Greetings need help with mounts, I was ordering and a suggestion to change them as a pair (there are 4 total, 2 front 2 rear) The issue I ran into was that the part numbers don't seem to match well between scuderia parts and my local dealer. the car is a 2007 vantage manual part numbers:
6G33-6A003-BC
6G33-6A003-AD
6G33-6068-AD
6G33-6068-BB
6G33-6068-AA
8D33-6A003-AB
As you can see there are 6 different part numbers I can guess the reason is some are for v12v/v8s/roadster/maybe sportshift or updated like a lot of parts. if someone can advise which one to get if there is a better version whether updated or improved for specific aspect of driving would be great thank you.
Old Sep 5, 2020 | 04:23 PM
MichaelD's Avatar
MichaelD is infamous around these parts
Googled it, found
FRONT ENGINE HYDRAMOUNT
The other numbers are probably engine mounts too. Nothing to do with photography then
Old Sep 5, 2020 | 06:06 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
FWIW, for the DB9 these came from the vast part bin of Ford/Jaguar and are the same as that used on a 2004 Ford Thunderbird, or a Jaguar S-Type/XJR...
Old Sep 5, 2020 | 09:57 PM
Abdullah37's Avatar
hmm still need more help to find out what I should get.
do they leak in the first place?
I was told contradicting info regarding them being filled with grease or not.
FXshooter
May 15, 2020 10:25 PM
buddyg
Apr 25, 2015 12:16 PM
brumma
Dec 28, 2011 07:06 AM
tomjack
Dec 8, 2010 08:16 PM
alex55
Jun 24, 2008 01:47 AM
