Coilover Upgrades - V8 Vantage
Old Oct 25, 2020 | 04:31 PM
COJimmy's Avatar
COJimmy is infamous around these parts
My 2015 has comfort suspension and I’d like to tighten up the suspension and eliminate body roll without making the ride really harsh. My use is primarily on the street. From all I’ve read it seems that KW and BC may be the best (only?) options. If anyone has done this mod I’d really appreciate your thoughts- pros/cons etc. based on your experience. Thanks.
Old Oct 25, 2020 | 06:16 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
If in your situation, I would probably either go with Nitrons (I have them on my Lotus and LOVE them, they are adjustable to dial in the ride/handling balance) or buy the factory sports pack, which will not only get you the stiffer shocks and springs but also uprate the sway bars and forged wheels..At least it did for my Vantage, perhaps the newer cars have different options. The Nitrons are constructed of aluminum and hand build in England, can you think of a better story to match an Aston Martin? To reduce roll without affecting ride, you probably should look into sway bars only. This will do exactly what you are asking.
Old Oct 25, 2020 | 08:27 PM
bavarianstance's Avatar
5 Year Member
bavarianstance is infamous around these partsbavarianstance is infamous around these parts
KW V3s are probably your best bet if comfort is your primary objective.
Old Oct 25, 2020 | 10:05 PM
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
I have the KWs and love them. It dialed in the ride quality and handling of my Vantage to a sporty setting with little body roll and comfortable enough for passengers to not complain.
Old Oct 27, 2020 | 11:07 AM
Deplorable1's Avatar
5 Year Member
Deplorable1 is infamous around these parts
Old Oct 27, 2020 | 11:50 AM
COJimmy's Avatar
I am curious about BC also. Hard to believe there are only 2 users on this forum that have made suspension changes...
Old Oct 27, 2020 | 12:32 PM
spyder997s's Avatar
Someone here has Nitrons and he didn't seem very happy with them.
https://www.6speedonline.com/forums/...ilovers-3.html
You may want to search to read all the opinions on suspension upgrades.
Old Oct 27, 2020 | 03:45 PM
PaperBoy's Avatar
5 Year Member
PaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud of
My Dampers were custom made for my Vantage. If I had to buy outside of my circle, id go with KW
That being said, Im running BC coilovers with custom airsprings on my driver and it still rides like a Lexus. if theyve (BC) moved the adjustment **** to the bottom of the rear shock, i would have no issue buying their product for my AM..... And they will let u order custom spring rates with theirs
Old Oct 27, 2020 | 06:47 PM
blue2000s's Avatar
...On the track. On the road he seems to like them a lot.
Old Oct 28, 2020 | 03:16 AM
Matt Barnes's Avatar
Matt Barnes is infamous around these parts
I am getting Ohlin Road and Track dampers made by a company based at the 'Ring would do suspension etc for Gt3 cars. They have been tested and dyno'd etc by Valiant_ecosse (instagram) a company would build vantage "clubsport" style cars.
Not cheap but tested and great quality
Old Oct 28, 2020 | 05:24 PM
DetomasoGTS74's Avatar
I have nitrons
and I’m very happy with them
Old Oct 29, 2020 | 12:42 AM
Old Nov 8, 2020 | 12:07 AM
Montana107's Avatar
Montana107 is infamous around these parts
I believe there is some reference to a thread I started so wanted to provide some final feedback - I have done a few things to correct my issues on track with the Nitrons. These were items I had to figure out on my own listed below - I also had to do some modifications to get the pin type adjusters to work but it came out nice in the end - Was never satisfied with the post sale service from Nitron but Stuart at Velocity AP is GREAT -
1) Changed to a 19inch wheel (BC Forged) - The 20 inch wheel diamiter was just to large for track work with this set up
2) Raised the ride height another ~1/4 inch
3) Increased spring rates slightly
My V8VS does not see track time much as I have a race car but wanted it to be well suited on track - I was finally able to accomplish this
Talk with Velocity AP - They can get you set up with a nice kit from Nitron with the lessons learned -
Old Nov 8, 2020 | 12:39 AM
thanks for the information! What was it about the 20” wheels that were an issue out of interest? Too skinny a tyre wall? What spec wheels are you running now?
Old Nov 8, 2020 | 07:30 PM
Montana107's Avatar
The diameter was larger on the 20 inch tires/wheels - This created less clearance in the wheel wells
I was running a 265-35-20 front and a 305-30-20 rear Sport Cup 2 - and went to a 265-35-19 front and a 305-30-19 rear Sport Cup 2 -
The wheels are 19x9.5" wide in front and 19x11" wide in the rear
