Rapide fuel pump and harness
Old Nov 8, 2020 | 08:11 PM
corveight's Avatar
corveight is infamous around these parts
My 2012 Rapide lost power and had the low fuel pressure codes. I found a service bulletin to replace the in tank harnesses along with an overlay harness to go from the tank to the fuel pump drivers. Does anyone know what the reason for the harness replacement? The right pump stopped working. Put power to it at the in tank harness. Pump won’t run. I’m going to assume the pump failed. Should I be replacing the harness also?
Old Dec 8, 2023 | 01:49 PM
crispydee's Avatar
crispydee is infamous around these parts
Did you get this sorted? I appear to have a pump thats died, any chance you found an alternative ?
Old Dec 8, 2023 | 05:02 PM
corveight's Avatar
Yes replaced pump and harness as the connector going into the tank had melted
Old Dec 8, 2023 | 11:53 PM
crispydee's Avatar
Hi, thanks for the reply, was that with genuine aston parts or did you find an alternative?
Old Dec 9, 2023 | 05:43 AM
corveight's Avatar
Genuine and as I recall there was limited stock
winnigt2
Nov 15, 2015 04:53 PM
BG305
Cayenne 955/957
Feb 11, 2015 07:14 AM
marsfire
Aug 8, 2011 05:22 PM
FAST FWD
Aug 20, 2010 11:31 AM
Me_qwkr
Jul 22, 2006 11:02 PM
