Door struts
Old Mar 7, 2023 | 08:22 PM
hueyhoolihan's Avatar
hueyhoolihan is infamous around these partshueyhoolihan is infamous around these parts
truth is, i suspect the concept that a gas strut for use in a door that will experience various forces depending on the terrain one parks on was overly ambitious to begin with. and cannot possibly satisfy everyone's expectations of what is and is not satisfactory.
Old Mar 8, 2023 | 05:32 AM
Mark Gronsbell's Avatar
Mark Gronsbell is infamous around these parts
I just replaced my driver side strut with an original Aston part. It works well, is relatively inexpensive and the task while a little fiddly was not difficult. Easier to go the OEM route every 5 or so years.
Old Mar 8, 2023 | 07:32 AM
Lefach's Avatar
Lefach is infamous around these parts
I did mine about a year ago with OEM and so far they are holding great.
Old Mar 8, 2023 | 07:56 AM
Sir Rothschild's Avatar
Sir Rothschild is infamous around these partsSir Rothschild is infamous around these parts
Does anyone have the OEM part #?
Old Mar 8, 2023 | 11:32 AM
Bob Duato's Avatar
Bob Duato is infamous around these parts
Replacement Option
Nearly identical, however I don't have the spec on the OEM stroke length. There's an option for 7.87" and 8.27".
I think stock are 108 lbs (in my notes, but not sure where I got that figure), and you can buy these up to 130 lbs.
I had bought some cheapo ones on Amazon that were 80lbs. They work decent, but I'll be replacing with the 110lbs from here shortly. Perhaps I'll test out the 130lbs too and see what they are like.
Old Mar 8, 2023 | 01:20 PM
spainconection's Avatar
spainconection is infamous around these parts
each one who sees their interest, but really, it is a waste of time------ the oem is the best part, but the human being must first lose his money, to later realize that he has lost the money and time----put an oem gas spring in your door and you won't be sorry
Old Mar 8, 2023 | 02:47 PM
Lefach's Avatar
I bought mine here:
Door Struts (V8/V12 Vantage, DB9/DBS, Virage) – Redpants Shop
This seems to be my part number 6G33-16C826-AB
Old Mar 8, 2023 | 06:17 PM
voodoocat's Avatar
voodoocat is infamous around these parts
The liftsupportdepot worked fine for hood, but overly high sprung for trunk (roadster). I recommend OEM as they have tested not just the length fit, but preload/compression that aftermarkets can't test. Dealer tech instantly spotted the trunk strut as too hard to close. Quality seem ok but obviously OEM parts have been tested thoroughly on the actual car.
It's not much more money, nothing compared to how much gas we have to put in.
Kalepsis
May 31, 2020 10:37 AM
shinjuku
Jan 7, 2016 09:08 AM
CJPatel
Apr 19, 2013 10:09 AM
plastique999
Jan 8, 2013 09:26 PM
