Oil Consumption in a Daily Driven Vantage V8
Old Dec 2, 2020 | 10:42 AM
M I Six's Avatar
M I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud of
Searched but could not find any information.
For those that drive a few times a week, what have you found your oil consumption to be? I am going through about 1 liter of 10w60 every 3000 miles. Is this normal? I am ordering the catch can kit to monitor more closely.
I admit I have not checked levels regularly and was shocked to be 2 liters down yesterday after about 6000 miles. I have done an oil change every 3000 up to now, but figured I should be able to go 6000 miles between with a good synthetic. So I do not think I noticed the consumption before as I simply drained and added 10 liters +/- to full.
Thanks for any insight.
Old Dec 2, 2020 | 01:56 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Completely normal.
Old Dec 2, 2020 | 02:18 PM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
Our 2007 V8V has about 43,000 miles. I don't have to add oil between oil changes which are done about every 5,000 miles. It may drop about 1/2 a liter. I have a catch can on ours and empty it as part of the oil change. Get 1/4 - 1/2 a cup.
Saying all that - I don' think 1 liter every 3,000 miles is out of line.
Kevin
Old Dec 2, 2020 | 02:58 PM
M I Six's Avatar
Thanks guys. I will have to check it more often then. We shall see what the catch can catches.
Old Dec 2, 2020 | 04:08 PM
ccfulton's Avatar
ccfulton is infamous around these parts
Catch cans are a wonderful thing.
If a PCV valve goes bad you can blow oil out the full load breather side into the intake tube / MAF / air filter and lose some from the sump that way. If you've had those off recently, did anything seem excessive?
Shortpballer
Nov 21, 2024 09:49 AM
Golfpunks
Oct 13, 2022 01:31 PM
mrgylex
Oct 20, 2015 03:45 PM
terminal_ac
Jul 7, 2015 08:59 AM
Savile Row
Nov 15, 2012 07:31 AM
