Prevalence of front cover oil leaks V8V and DB9
Old Apr 15, 2021 | 01:42 PM
slkret123's Avatar
5 Year Member
slkret123 is infamous around these parts
So I've been reading a bit about the "dreaded" front cover oil leak in the V8V engines. I've also found reports of the same issue on the V12 in the DB9. I understand that forums tend to over emphasize problems with cars. Having said that how prevalent is this problem? I find it odd that this same "problem" shows up in 2 completely different engines.
Steve
Old Apr 16, 2021 | 07:36 AM
J doubleU's Avatar
Just like any other engine, some leak some don't.
Old Apr 16, 2021 | 05:58 PM
slkret123's Avatar
5 Year Member
While that is true some leak sites are more common on a given engine. The front cover on the v8 and v12 engines seems to be that spot. All I'm asking is how common this is in those engines.
Steve
Old Apr 16, 2021 | 06:23 PM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
Hard to quantify but based upon,
a) my personal experience with a then low mileage ‘14 4.7
b) many years of following Aston specific boards and blogs
c) anecdotes regarding temporary dealer fixes (application of sealant) to avoid the necessary warranty work
I would say fairly common but less common than tail light condensation.
Old Apr 16, 2021 | 07:00 PM
slkret123's Avatar
5 Year Member
So, how effective was the sealant warranty dodge "fix"?
Steve
Old Apr 16, 2021 | 07:13 PM
Hedged's Avatar
Effective for the remainder of my warranty evidently. I was unaware of any leak issue while under warranty and subsequently paid out-of-pocket for the full Monty at an indie that noted evidence of the half-*** “fix”. As you may know the labor involved pushes the cost over $3K, but some folks on here have tackled the job DIY.
Old Apr 16, 2021 | 07:49 PM
Mike Gray's Avatar
5 Year Member
Mike Gray is infamous around these parts
I assume you have seen this thread re: oil leaks on our cars: https://www.6speedonline.com/forums/...l-leaks-2.html
My experience with my 2013 V8V 6MT is post #35. With this being a later car with low mileage, no abuse and perfect maintenance, I thought I'd dodge this bullet. Sadly, I was mistaken. I detest fluid leaks!!
Old Apr 16, 2021 | 07:51 PM
slkret123's Avatar
5 Year Member
That's a sh**ty deal by AM.
Steve
Old Apr 17, 2021 | 12:13 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
Any engine leak on a well built (unworn out) engine are caused primarily by three reasons;
1) Lack of use. Seals dry up and rot. Frequent dry starts damage lip seals like front and rear main seals. So cars with low mileage will have these issues. If you buy a 10 year old car with 10k miles on it. That thing is a ticking leak bomb!
2) PCV issues causing excess pressure in the crank case will cause seals to leak as well.
3) Infrequent oil changes, or leaving old oil during storage periods. Engine oil becomes acidic over time and if you leave old oil over storage periods, that oil will eat at seals.
A lot of these cars are just toys for people with many toys and as such they don't get used or serviced often.
Pro Tip. Use your car weekly. Change the oil regardless of mileage before winter storage. Fix PCV issues before they cause more serious issues!
Old Apr 17, 2021 | 12:38 PM
Hedged's Avatar
Good advice....but, just as a point of reference, none of that applies to my one-owner, very well maintained & driven 4.7 Vantage.
MRCW's Avatar
tiny oil leaks, drips, aren't the end of the world... piece of cardboard under the engine, periodically clean the undertray...
Why all the fuss and concern? steady leak, sure but few drips?
Old Apr 17, 2021 | 12:44 PM
sf911c2's Avatar
sf911c2 has a spectacular aura aboutsf911c2 has a spectacular aura about
Steve
I had this issue on my 2013 v8v and dealer fixed under warranty. My car had 10k miles and was 4 years old at the time. The car was maintained by 1st owner and I only had the car 1 yr when found leaking by the tech (not sure when it started). My service tech said it probably affects ~10% of cars and he does 1 or 2 V8's leak fixes per year. It does seem random and can happen at low or high mileage. It is a very expensive fix ~$4k since you remove the whole front end of the car (not so on v12 though). I don't have a reference on how many v12's...Good luck...
Old Apr 21, 2021 | 11:58 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
4) Material/gasket design issues that were not exposed in the manufacturer's development process, hence the warranty repair. Aston, Ford, Subaru, Porsche, Mercedes the list goes on. So many manufacturers have had issues with oil seal gasket design...
Old Apr 21, 2021 | 01:28 PM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
I have to agree with blue2000s response. Had the issue on my 2012 V12 Vantage...covered by extended warranty.
My car did not suffer from lack of use...nor poor maintenance.
Thanks,
JH
Old Apr 26, 2021 | 02:24 PM
deckman's Avatar
Eventually all engines leak if they live ling enough.Not many 10-15 year old cars aren't seeping something, somewhere.
