Reverse gear chime stays on
Old May 19, 2021 | 08:35 PM
Norgeiron's Avatar
Norgeiron is infamous around these parts
I just got my 2011 Vantage V12 manual and I am learning to adjust to quirks already. When I put the car in reverse, a chime goes off and the Reverse light goes on. However, when I am done backing up, and put it in first and even start driving forward, the reverse chime stays on. Aargh! I have to stop the engine and restart to get the chime to go away. Does anybody have a solution to this one? I would be willing to remove the chime module if I knew where to access it and what it looks like.
Old May 20, 2021 | 08:55 AM
MRCW's Avatar
perhaps it's the rear sensor... try pressing the rear sensor button.
Old May 20, 2021 | 01:29 PM
Norgeiron's Avatar
MRCW,
Pardon my ignorance, but where is the rear sensor button? Is it on the center stack? I looked in the manual and can't find it.
Old May 20, 2021 | 08:08 PM
MichaelD's Avatar
MichaelD is infamous around these parts
Its one of the large buttons at the bottom of the centre stack. There will be a red light on when the sensors are active. If you start driving the rear sensors turn off at something like 5mph, so the sound should stop then.
Its likely to be a failed sensor causing the problem, they are the same as Jaguar and Land Rover sensors, and pretty cheap if you buy from someone other than Aston Martin
Old May 20, 2021 | 09:42 PM
Norgeiron's Avatar
Thank you MichaelD, for the valuable information. I am going to have to do a lot of this stuff on my own as there is no dealership within 2,500 miles of Oahu, so you guys are an extremely valuable resource. Mahalo
Old May 21, 2021 | 11:16 AM
Irish07@VelocityAP's Avatar
When you shift back to a forward gear and go over something like 4-10kph, the Park Distance Control will deactivate for it's no longer required.
If it's staying active then the PDC system is seeing reverse selected.
Does the "R" L.E.D turn off in the instrument cluster when the shifter is pulled out of reverse gear?
Btw, if your not near any objects and the PDC is going crazy, you would also have an issue with sensors are harness....or simply just a dirty sensor or something attached to bumper which is too close (vinyl wrap, carbon lower spoiler, license plate mount, aftermarket camera)
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
AZV8s
Apr 29, 2020 06:33 AM
958 Dan
Cayenne 958
Aug 9, 2019 02:50 PM
captd108
Jul 18, 2019 10:31 AM
jonflip29
Jul 23, 2014 11:46 AM
AstonAficionado
Aug 27, 2012 02:55 PM
