PPF glue removal
Old Jul 27, 2021 | 08:36 AM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
PPF glue removal
The ppf on the front diffuser was marked up. So I removed it. Now I have a mess. The glue is almost all left on the car. I have tried multiple different things to remove the glue. I think it is going to be a long and tedious process removing it. Any help or suggestions would very much be appreciated.
Old Jul 27, 2021 | 09:05 AM
61mga's Avatar
61mga is infamous around these parts
i suppose if i had goo on my car and wanted it gone, i'd probably invest a few bucks in something called "Goo Gone". truth in advertising being what it is, i'm not sure i'd get my hopes up though..
if you go that route i see they have a wide selection: "Original", "Paint", "Home", "Outdoor", "Professional", "Automotive" (sounds encouraging), "Personal Care" (sounds creepy), and last but not least, "Arts and Crafts". a "Goo Gone" for every occasion it appears.
BTW, i've never tried it. good luck!
Old Jul 27, 2021 | 10:09 AM
Hybrid's Avatar
Hybrid is infamous around these partsHybrid is infamous around these parts
I use WD-40
Old Jul 27, 2021 | 10:26 AM
MRCW's Avatar
hi gene...I had some PPF removed from one of my porsches... the guy used a steamer to heat it up and removed slowly...
If you didn't use a steamer initially, perhaps heating up the glue could help.
Old Jul 27, 2021 | 11:56 AM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
I'd take it to a professional, suffer the embarrassment and the cost...and learn from my experience!
Thanks,
JH
Old Jul 27, 2021 | 12:18 PM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
Larry from Ammo NY dumps boiling water on PPF and slowly peels it off while its hot
Old Jul 27, 2021 | 12:59 PM
Gene G's Avatar
Well I finally got all of the glue off. I did use Goo Gone. It is almost like a lubricant and then just used my finger nails. Then polished with two stages of polish and then a wax. I tried alcohol, WD-40, Goof Off, turpentine, mineral spirits, and acetone. None of these worked. I guess the manufacturer of the ppf doesn’t intend for it to be removed. Most probably the first owner would have sent it down the road to another owner and not worry about the film. All is good now just a very tedious job of removing the glue.
Old Jul 28, 2021 | 02:24 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
You're brave using acetone on paint.
Old Jul 28, 2021 | 08:55 PM
balefire's Avatar
balefire is just really nicebalefire is just really nicebalefire is just really nicebalefire is just really nice
I did this on several year old PPF on my GT3. Miserable experience with goo gone. Took hours. I'd pay professional next time.
Old Jul 29, 2021 | 08:30 AM
txtonyo's Avatar
5 Year Member
txtonyo is infamous around these parts
Was going to suggest a clay bar. Just depends on how much muscle is needed. Also, a plastic tool such as the ones used for interior trim removal along with detail spray or foamy soap solution might work. I had to remove an old PPF from Audi headlights and it came off if very small pieces but the aforementioned tools were instrumental to the success . . . which took about 2 hours for the entire job over several days.
Old Jul 30, 2021 | 06:54 AM
Gene G's Avatar
On mine the whole surface was coated with glue. But it is all off now. I have taken it off of several cars before but this was really a mess and very sticky.
Ghost Ryder
Cayenne 958
11
Jun 23, 2017 06:25 PM
Stone_05
Nov 1, 2016 11:37 AM
quick
Jan 7, 2012 05:10 PM
Car-Narcissist
Apr 10, 2011 06:09 AM
str8blst
May 10, 2007 10:05 AM
