I'm glad I did the thermostat
Old Oct 2, 2021 | 08:48 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
07 Vantage-23,000 miles- I'm at my 5 year mark to change coolant. I didn't do it last time so I figured I'd do the better Ford (Motorcraft) part just for peace of mind. I had no temperature issues with the car. So I was surprised to see that the gasket had pulled off of the thermostat when I got it apart. I'm glad I did it now!
Old Oct 2, 2021 | 09:06 PM
J doubleU's Avatar
Nice, at least you have peace of mind that it's good for another 5+ years and then some.
Old Oct 3, 2021 | 06:39 AM
V8Vdrew's Avatar
5 Year Member
V8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the rough
Nice! Glad you caught it in time. Im about to do mine. Do you have the part number for the ford part? Thanks!
Old Oct 3, 2021 | 08:34 AM
blue2000s's Avatar
It's Motorcraft RT1163 Thermostat. I will say, the spring on the Motorcraft part is noticeably stiffer. I could push and turn the Vantage part by hand to get it out of the housing. For the Motorcraft part I had to use a clamp to hold it down while I used a screwdriver to turn the tabs.
Old Oct 3, 2021 | 03:47 PM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
I had to replace the thermostat on our 2007 V8V 5 years ago when we purchased it with 28,000 miles. It was running cold and the rubber was split like yours. At least it was all still there so none broke off and got stuck In a cooling passage.
it now has about 43,000 miles and is due for a coolant change again.
Old Oct 3, 2021 | 07:46 PM
blue2000s's Avatar
On the Motorcraft part, the gasket is molded all the way around the metal flange. Presumably it will do a better job of holding together.
Old Oct 4, 2021 | 03:07 AM
cadman's Avatar
5 Year Member
cadman is a jewel in the roughcadman is a jewel in the roughcadman is a jewel in the rough
i found the same (broken stat) when i did coolant flush
Slider
Feb 5, 2023 06:56 AM
Oversight
May 24, 2016 10:39 AM
JSavinoJr
Mar 13, 2013 03:02 PM
Kai@ELITEMS
Cayenne 955/957
34
Dec 5, 2011 08:14 AM
johnnytaboo
Oct 23, 2008 11:20 AM
