Window, reset, pull fuse, dont work.
Old Oct 26, 2021 | 05:11 PM
Astonfreek's Avatar
Astonfreek is infamous around these parts
My left window, moves up/down 4in at a time. the window reset and calibration doesnt fix it. and i pulled f82 and f83 but it doesnt fix it. right side is ok. left side still doesnt work properly. i cannot find any other thread with this problem. Any other solutions besides the 5sec reset and the fuse pull ?
Old Oct 26, 2021 | 05:19 PM
bavarianstance's Avatar
5 Year Member
bavarianstance is infamous around these partsbavarianstance is infamous around these parts
door modules might need replacing
Old Oct 26, 2021 | 05:49 PM
Astonfreek's Avatar
The window works. just stops every 4 in. very irritating. also it doesnt slightly open up or down when. opening and closing the door. i will try taking the door cover off and disconnecting the module and see if that works. I'm really not keen on taking the battery off, thats the very last option for sure.
Old Oct 26, 2021 | 09:19 PM
J doubleU's Avatar
Your safe with a battery disconnect (-negitive) as everything else is ok as far as memory except OBD monitors. #1 fault of issues is a low battery condition to start with. Make sure it has been tested and or replaced with a proper charge.
JW
Old Nov 14, 2022 | 10:05 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
JW
I'm having the exact same issue. Haven't tried pulling the fuse yet but did you manage to get the problem sorted? New door module?
Old Nov 15, 2022 | 04:28 AM
handyman2009's Avatar
Veteran: Canadian Forces
Door Module replacement means a trip to the dealership to get it programmed, start with a fresh battery then a reset with the fuse removal. If everything else fail then a new module but I would go for the newest iteration of the door module and you will have to replace both door as the first and second version are not compatible
Old Nov 15, 2022 | 05:14 AM
sdekoning's Avatar
Thanks; will give it a fuse pull shot and take it from there. Will post the outcome whichever way it goes.
randyb
May 2, 2022 02:34 PM
baziturbo
May 17, 2016 12:33 PM
Rumster
Mar 10, 2015 04:12 PM
mrdorkdar
Jul 14, 2013 12:55 AM
Korn58
Jun 20, 2012 06:15 PM
