2009 DB9, strange turn signal issue
Old Dec 10, 2021 | 04:04 PM
ipassgas's Avatar
ipassgas is infamous around these parts
Hello!
I have a 2009 DB9 Volante with a strange issue (at least I find it strange) and I'm hoping it's a known issue with a known solution. When I activate either side turn signal, or the hazard lights, The front and rear bulbs illuminate once, go out, and then the flasher relay flashes fast and the dash gives a bulb error message. During this, the side mounted turn signals flash quickly.
To sum up, the 4 corners will only flash once, then the error message is triggered and the side flashers go rather quickly.
Any ideas where I should investigate first?
Thank you.
Old Dec 12, 2021 | 11:51 AM
sliderule01's Avatar
sliderule01 is infamous around these parts
Check the bulbs and make sure they are all properly seated. Have you verified that the bulbs actually light? If they do, then maybe it is a bad flasher relay. That should be pretty cheap and readily available.
Old Dec 12, 2021 | 12:32 PM
ipassgas's Avatar
Yes, the bulbs light once. Then the corners stop and the bulb error message appears. The fender mounted lights continue to flash.
Thank you for the suggestion.
broncoupe
Nov 8, 2021 07:08 AM
dwright
Sep 8, 2021 05:16 PM
gtmule
May 6, 2021 07:42 PM
LIDB9
Oct 17, 2016 04:36 PM
Wildcat1212
Nov 8, 2014 05:53 PM
