Air intake duct keeps slipping off 07 V8 Vantage
So my air intake ducting keeps slipping loose on the manifold inlet and lets in air, confirmed with a shot of ether at idle. Im thinking that a normal hose clamp that tightens with a screw vs the factory plastic one might remedy this situation but I have not found one with a skinny band width like the factory one. Also the weight of the rubber ducting seems to contribute to this, wanting to work the hose loose at a downward angle. A support bracket would probably remedy this situation but seems extreme.
Any ideas or other ways to solve this from others?
07 V8 Vantage Manual 6 speed.
Thanks,
Thanks,
Thanks, I could not find the Norma in stock anywhere but I did eventually find these and they work to fix the issue. https://www.ebay.com/itm/252897737838]Narrow Band 9mm Steel Hose Clamp 90-110mm Made in Germany Pack of 2 HC90-110/9 | eBay
M I Six
Sep 13, 2020 05:13 PM
Vergis
Aug 6, 2013 12:01 PM
