How does one remove the cant rail?
Old Feb 28, 2022 | 01:24 PM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
How does one remove the cant rai (AKA A pillar trim that extends all the way back along the roof)l on the V8 Vantage? Aston1936 has a DIY for the DB9 MY 05 but I want to be sure or fairly sure it's the same procedure before doing this. I need to remove the rear headliner panel to access the underside of the antenna, but the workshop manual simply states "remove cant rail trim panel and remove rear headliner panel" which is less than informative. If anyone knows I'd appreciate it. I will put a DIY up for the antenna base replacement if so. The gasket on mine is cracked and split. Florida sun I suppose.
Old Mar 1, 2022 | 09:27 AM
embdenb's Avatar
Years may differ, however removed mine by removing the plugs ( covered in same material as headliner) This give you access to screws holding the rail. Hope this helps.
Old Mar 1, 2022 | 09:39 AM
Marmot's Avatar
5 Year Member
My concern is damaging the covered plugs, are they simple pop outs or do they require some level of effort to remove them?
Old Mar 2, 2022 | 06:18 AM
embdenb's Avatar
I used a small metal pick to lift them from the side . This way any damage would be covered when you reinstall them.
Old Mar 2, 2022 | 08:31 AM
Marmot's Avatar
5 Year Member
Thanks embdenb, I'll give that a shot.
nbressette
Jan 20, 2020 09:38 AM
mkzhang
May 15, 2019 12:30 PM
Ghost Ryder
Cayenne 958
11
Jun 23, 2017 06:25 PM
Cole1766
Cayenne 955/957
Jun 5, 2017 07:51 AM
Carbon6Nik
Cayenne 955/957
May 11, 2012 07:01 AM
