ASM I gear oil
Old Apr 27, 2022 | 06:32 AM
MRCW's Avatar
ASM I gear oil
Hi all
I know there is a sticky on this subjet but it was started back in 2013 and I wanted to get a little update, if any, from a more recent perspective....
Planning to change gear oil in my 2009 Vantage. It's been about 5 years...I've read the sticky and also read Rich's commentary and watched video on RedPants.lol... Easy enough process but what about any recent developments in the 70W fluids for the ASM?
I can get the Castrol BOT 270A fluid from my local Aston Dealer, at $65/lt or RedPants at $55/lt plus shipping...I'm looking to see if anyone has used something more readily available. I saw some comments on Redline products but most were going to use on the MT rather than the ASM...BTW. I am in Florida, no very cold weather, etc. which I understand was the reason behind a custom blend ( colder, thicker...etc.) but if I ever sell the car, want to make sure the fluids are compatible,
Any thoughts appreciated..
Old Apr 27, 2022 | 06:58 AM
J doubleU's Avatar
Red Line MT LV 70-75w @Walmart for less than $25 a quart. ASM doesn't mind what spec. I've seen people put 80-90w and have no issues. But I'd stick with BOT 70 or Red Line for a good time.
Old Apr 27, 2022 | 10:26 AM
MRCW's Avatar
thanks...I looked at redline specs and is recommended in place of the Castrol BOT270A in AM on their website.
Thanks! Saves me $200 so I can buy a full tank of gas!
Old May 20, 2022 | 01:17 PM
mrtzmd's Avatar
mrtzmd is infamous around these parts
I just changed my ASM gear oil using Redline but I was short with the gallon, so don't buy just the gallon, add on the 1 liter bottle as it takes 4.5lts. Good deal on Bimmerworld.com with free shipping.
Mine has 45k miles and likely never changed, oil was dirty and smelled bad. A lot of residue on the filter and drain plug but fortunately no metal shavings.
BTW, Anyone know the measurements for the copper crush washers? I can't find one of the washers and put the old one on temporarily until I can source one.
Old May 20, 2022 | 01:39 PM
J doubleU's Avatar
22mm ID 28mm OD
Old May 20, 2022 | 01:40 PM
mrtzmd's Avatar
Thank you!
Old May 20, 2022 | 04:05 PM
MRCW's Avatar
I couldn't source the o ring for the filter. Local dealer is out... anyone know the size?
Old May 20, 2022 | 04:29 PM
J doubleU's Avatar
I've reused it, never had a leak.
Old May 20, 2022 | 04:37 PM
MRCW's Avatar
ok great
embdenb
Oct 23, 2015 02:58 PM
Vergis
Aug 1, 2013 11:39 AM
barncobob
May 10, 2013 07:37 PM
XJRS Owner
Nov 28, 2012 11:19 AM
