New to me 2007 V8 Vantage...and a question?
Old Jun 3, 2022 | 01:35 PM
cbj5259's Avatar
cbj5259 is infamous around these parts
Hi all! Just recently picked up a 2007 V8 Vantage with a little over 7000 miles. Got a PPI done and everything checked out fine considering its a 15 year old car. Two things that I've picked up on that I have questions about. There are two body colored trim pieces on either side of the rear license plate that seem to be, for lack of a better word...wiggly. Is this normal? I didn't want to futz around with them too much but it looks like they are removable in some way. My other question is that I noticed that when I open my driver's door there seems to be an auto down function that lowers the window a small fraction, however this function doesn't seem to activate on the passenger door when it's opened and closed. The window clears the body and trim but barely. Any information on either or both questions would be greatly appreciated! Pictures of car and the trim pieces I'm talking about attached.
Old Jun 3, 2022 | 01:42 PM
christopherlem's Avatar
5 Year Member
christopherlem is infamous around these parts
Congrats on your purchase - the look on the woman's face says it all!
In regards to #2 - see this post:
https://www.6speedonline.com/forums/...dow-reset.html
Old Jun 3, 2022 | 01:44 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Your owners manual has instructions to reset your window drop. I believe the bumper will need to be removed to tighten or replace the covers in back. Behind them are 2 aluminum impact extrusions that are riveted to the frame.
Old Jun 3, 2022 | 02:25 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Congrats and welcome..hope it’s a simple fix for ya..sounds like it should be..cheers
Old Jun 3, 2022 | 04:09 PM
cbj5259's Avatar
Ah, ok...thanks for the info. I'm assuming any competent body shop should be able to handle this or should I go to an Aston specific place?
Old Jun 3, 2022 | 04:27 PM
5 Year Member
You know it's been quite awhile since I removed and replaced the bumper. Phone your dealers service department. You might be able to snap them off and replace with new ones, they are cheap, you will just need to have painted to match.
Old Jun 3, 2022 | 04:34 PM
sxates's Avatar
sxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond reputesxates has a reputation beyond repute
I remember seeing this one for sale when I was looking at buying mine - super clean example, congrats!
Old Jun 3, 2022 | 04:38 PM
61mga's Avatar
61mga is infamous around these parts
if you don't have a jack and jack stands or don't want to bend over to get under the car the only option is to take it to a garage. i would trust (as long as i was standing there) just about any competent mechanic tighten them up, assuming it's just a nut or two. but if you take it to an aston dealership you'll be bending over whether you want to or not.
i suspect those pads are removable to accommodate the wide english and european license plates. it's possible the car was recently in europe. who knows?
and i think the amount the window moves is determined by an automatic "learning" process, and will depend on a number of factors. some may not have to move at all.
Old Jun 3, 2022 | 07:00 PM
cbj5259's Avatar
I did the window reset procedure listed in the manual and all works fine now!
There is an indy Aston mechanic/restoration shop near me that is probably more reasonable than the closest dealership which is well over an hour away. I may have them look at those bumper inserts. Honestly, it looks like they have been "wiggly" for a while so may just leave them be. The car came from Florida and prior to that was in Puerto Rico. It's a one prior owner car.
Old Jun 3, 2022 | 08:20 PM
61mga's Avatar
why does everybody else's vantage look shinier than mine? *shoulder slump"
Old Jun 4, 2022 | 06:03 AM
embdenb's Avatar
I know you you feel (smile)
Old Jun 4, 2022 | 07:07 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
But then everyone else thinks your Aston is shinier than theirs too...
Tremelune
Jul 26, 2023 11:00 PM
marcus550
Jul 19, 2021 05:41 PM
007JB
Oct 14, 2019 04:36 PM
XWCGT
Nov 19, 2014 11:11 PM
X7LDA
Oct 16, 2013 08:38 AM
