Can't find OBD2 Port
Old Aug 2, 2022 | 07:55 PM
SemiF19's Avatar
SemiF19 is infamous around these parts
Ok, let me start out by saying that I've googled this and watched videos and I must be just a complete moron because I absolutely cannot find where the OBD2 port is on my 2006 Vantage. If anybody can help me out please do so.....thank you!
Old Aug 2, 2022 | 08:20 PM
SemiF19's Avatar
Never mind.......found it......
Old Aug 3, 2022 | 07:29 AM
MRCW's Avatar
On my 2009 there are two
Old Aug 3, 2022 | 07:56 AM
XJRS Owner's Avatar
There’s only one OBD port. The other is the body systems port.
Old Aug 4, 2022 | 04:04 AM
a102768's Avatar
a102768 is infamous around these parts
They are both still OBD ports. The workshop manual refers to them as:
OBD II Connector (Powertrain A)
OBD II Connector (Body B)
Old Aug 4, 2022 | 08:23 AM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
Mine only has a single OBD-II port for both powertrain and body. It is a 2017 Bosch ECU though.
Old Aug 4, 2022 | 08:24 AM
XJRS Owner's Avatar
No they’re not. An OBD port can be read by any generic code reader. The body port is proprietary to the car manufacturer and there is no requirement that OBD readers must be able to access it. Just because the connectors are OBD compliant does not make it an OBD port
Old Aug 4, 2022 | 05:29 PM
MRCW's Avatar
OBD-II diagnostic trouble codes (DTCs) contain 1 letter and 4 numbers, and are divided into the following categories:
  • B – Body (includes air conditioning and airbag) (1164 codes)
  • C – Chassis (includes ABS) (486 codes)
  • P – Powertrain (engine and transmission) (1688 codes)
  • U – Network (wiring bus) (299 codes)
It's On Board Data port. Some are for engine/ emissions/powertrain codes... other are body,, chassis and network codes.
Generic code readers can read engine and emissions codes...
msrp
Jul 21, 2022 09:27 AM
Argus
Oct 21, 2021 09:17 PM
SlinginHoss
Jan 23, 2015 08:20 AM
g3t_t0rk
Jul 14, 2011 08:25 AM
