HID Headlight leveling
Old Aug 13, 2022 | 11:19 AM
MRCW's Avatar
Hi All
2009 Vantage with HID lights...Noticed that when I turn on my headlights, they don't move up and down (auto leveling test) Thjis just recently happened. Everything else is fine, no condensation, etc. It's both headlights... Does anyone know if there is a separate fuse to check for this function?
Old Aug 13, 2022 | 11:24 AM
J doubleU's Avatar
There is a module under the dash drivers side. They like to fail sometimes. Have you checked codes? If it sees a fault it will default to low position.
Old Aug 13, 2022 | 01:16 PM
MRCW's Avatar
thanks I'll put my foxwell on it. Also looks like there's a fuse in the cabin box I'll check. Thanks
UPDATE- Pulled fuse 53 ( it was OK) and reinstalled it. Now the module works again. British Glitch!
Old Aug 13, 2022 | 05:31 PM
goodshot's Avatar
goodshot is infamous around these parts
I am tagging on in here. My headlamps do the self-test at startup but they always seem like they are aimed ridiculously low.
Old Aug 15, 2022 | 10:06 AM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
There are panels inside the front fender liners, right behind the headlights. When you remove them you will see adjustment screws for vertical and horizontal aiming.
Old Aug 15, 2022 | 10:25 AM
J doubleU's Avatar
In your owners book it describes the process fairly well. T-20 for the adjustment fixings.
Old Aug 15, 2022 | 11:42 AM
spainconection's Avatar
spainconection is infamous around these parts
the older 2006 models also do that recognition ???? I swear I turn on the lights and I don't notice movement ????
Old Aug 15, 2022 | 02:43 PM
goodshot's Avatar
Mine is an '06 and has self-leveling HIDs, yes.
I read somewhere there are level sensors on the front and rear control arms that send a signal to the leveling module to keep the headlights from point up when the vehicle is loaded. If those fault they point downwards to prevent dazzle.
I have not looked had time to investigate this but this it what it seems like mine are doing, they do the self-test but aim downwards to where it feels like I can only see 30ft in front of the car.
Old Aug 15, 2022 | 05:09 PM
J doubleU's Avatar
They probably have never been adjusted correctly from the beginning. If they do the nod on startup I would definitely adjust them upward.
Old Aug 22, 2022 | 01:18 PM
power on lights ..in 1 sec. movement and stabilizes....test ok
Old Aug 22, 2022 | 05:46 PM
a102768's Avatar
a102768 is infamous around these parts
I only ever see my headlight do the self test when the lights are on auto, presumably because they come on immediately if I am parked in my garage. My '07 was the same.
Old Aug 22, 2022 | 08:22 PM
J doubleU's Avatar
As stated before, lamps on key off and be facing a wall or similar close flat surface 5-10ft away. Key position II. Within a few seconds you should see a movement if working correctly.
jonguffey
Cayenne 955/957
Sep 23, 2020 10:07 AM
randyb
Oct 29, 2016 02:22 PM
PhatchitC4s
Aug 6, 2011 02:14 PM
oregondave
Jul 17, 2009 11:44 PM
