2010 v8 vantage keys
Old Sep 12, 2022 | 02:26 PM
bondjbond's Avatar
bondjbond is infamous around these parts
I just got the car and was looking through the manual it mentions a metal key you can use for the door if your remote fails , anyone know where to find one ? thanks
Old Sep 12, 2022 | 03:24 PM
TiAg's Avatar
TiAg is infamous around these parts
I paid about $500 for mine at the dealer when my battery died and the car was locked.
Old Sep 12, 2022 | 04:46 PM
bondjbond's Avatar
couldnt you just replace the battery ?
Old Sep 12, 2022 | 11:27 PM
happyh's Avatar
happyh is infamous around these parts
I got one from Aston Martin works in Newport Pagnell,about £100.They will take an order over the phone and post it to you.You'll need to send them a copy of your V5 for proof of ownership but also to identify the correct key for your car.
Old Sep 13, 2022 | 03:12 AM
bondjbond's Avatar
thanks
Old Sep 13, 2022 | 09:38 AM
Stu-in-canada's Avatar
Stu-in-canada is infamous around these parts
You can get one here https://astonmartinbits.com/models/5...age/parts/5077 if you're in the UK they will cut it as per VIN. Outside the UK....
...Any auto locksmith can make a Tibbe key (ford/volvo) using a lockpick that reads the code from a device they put into your lock, they read the numbers off that and cut any tibbe key blank. Im in the same situation, and cost in canada is $175 ($130 USD) including the key blank.
Dealer wanted over $500 in Canada to create a key for me.
Hope that helps
Old Sep 15, 2022 | 03:15 AM
TiAg's Avatar
unfortunately the car was locked shut in a very tight spot in my parking garage. Could not open the car to access the battery or open the hood to jump it. Ive learned since that i could havw removed the front grill and opened the hood for a jump. Oh well.
Old Sep 15, 2022 | 05:22 AM
bondjbond's Avatar
oh, i thought you meant the battery in the remote , sorry . thanks for the info. While im on the subject of remotes , does the remote have to be reprogrammed if you replace the battery ?
Old Sep 17, 2022 | 09:14 AM
J doubleU's Avatar
Short answer No. Batteries last a long time so no need if it's working. Message will display in the IC indicating to change it. Key programming is retained in the car and you should never have an issue when replacing the cr2032 battery.
Old Sep 17, 2022 | 09:23 AM
bondjbond's Avatar
thank you sir !
bondjbond
Sep 7, 2022 08:08 AM
sscottdvm
Jul 24, 2021 09:44 PM
dsi
Nov 1, 2012 04:45 PM
jjparkusa
Sep 8, 2011 09:36 AM
irvineboy
Oct 24, 2008 03:33 PM
