DB9 Oil Drain Plug Size & Thread?
Old Nov 22, 2022 | 07:28 PM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
Does anyone know the size and thread of a Gen 1 DB9 oil drain plug? I believe the DBS, V12V, and Vanq2 also use the same plug. I threaded mine into one of those metric thread identifier devices at my local hardware store and it screwed into the 12mm x 1.75/coarse fitting, but it felt a bit sloppy. Anyone know for sure?
Thanks!
Old Nov 22, 2022 | 09:28 PM
J doubleU's Avatar
12x1.75mm is correct your local hardware store has probably been used frequently. FORD based drain plug can be purchased at many locations
Old Nov 23, 2022 | 09:00 AM
zuman's Avatar
Thanks, J doubleU!
Old Dec 1, 2022 | 10:57 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
I wrote up a little about the drain plug here; https://www.6speedonline.com/forums/...il-change.html
Old Dec 2, 2022 | 01:52 PM
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
Thanks!
The drain plug threads on my 2009 V8 Vantage are 14 x 1.5. The drain plugs are identical to the ones used on the 2002/2011 Ford Fusion.
Old Dec 3, 2022 | 10:56 AM
zuman's Avatar
Thanks, GWP.
This is just to emphasize to owners that the drain plugs for the V8V and V12 are different. As J doubleU noted, the V12 plug thread is 12mm x 1.75.
Stucat
Apr 15, 2023 01:47 PM
AstonCarma
Jan 16, 2022 04:18 PM
zzzamdb9
Oct 19, 2019 10:04 PM
cuddapah
Nov 5, 2017 03:58 PM
Wildcat1212
Jun 3, 2014 08:49 PM
