2020 Vantage-Reduced Engine Performance
Old Mar 3, 2023 | 08:03 PM
powerhouse21's Avatar
powerhouse21 is infamous around these parts
Hey guys,
I picked up a 2020 v8 vantage not too long ago and I just started to get the following error: "reduced engine performance service required" ...I'll add to this that the battery appears to be losing steam as I had to jump it the other day. Any ideas as to what this *could* be? Is it related to the battery?
Old Mar 3, 2023 | 08:15 PM
Endeavour32's Avatar
Endeavour32 is infamous around these parts
Change your battery, that is most likely the issue. I've read about many other owners in the new Vantage that have this issue and the problem is solved with a new battery. The fact that you think your battery is bad almost certainly makes it the most logical culprit.
Old Mar 3, 2023 | 08:18 PM
Copy that, I had seen one person report it but good to know others have solved this issue with a simple battery swap.
Old Mar 3, 2023 | 08:21 PM
When you swap the battery it is easiest if you remove the fuse box above the battery. I believe it is only two bolts that old it in place. Let us know if it solves your issue.
Old Mar 3, 2023 | 08:24 PM
Thanks for the heads up! I'll be sure to follow up after the swap.
Old Mar 4, 2023 | 03:30 AM
hueyhoolihan's Avatar
hueyhoolihan is infamous around these partshueyhoolihan is infamous around these parts
i suspect that replacing batteries and concomitant charging system components has increasingly become a first line response to many problems is that many systems are run by computers and they have strict voltage requirements and refuse to work properly otherwise. additionally, their only recourse when insufficient electricity is provided is to offer a warning signal on the dashboard and refuse to perform altogether.
Old Mar 5, 2023 | 02:13 PM
Have a tuesday appointment witth the dealer for reg service and i'm going to have them check it out. Haven't had any issue with starting it or any error codes in days though.
Old Mar 8, 2023 | 07:04 AM
Dealer did full CPO inspection, found battery did fail the load test and is being replaced to the tune of $1200 (high to me). Car has been running fine for a week now regardless of batttery state.
Old Mar 8, 2023 | 07:06 AM
WOW! You were really charged $1200 for the battery? Or was that Battery, installation, and CPO inspection?
Old Mar 8, 2023 | 07:08 AM
I haven't agreed to them doing any of the work yet, that's just what the quote has. $680 battery, 433 labor, 1114 total, so not quite 1200 but yeaaaaa. I've used AGM batteries before and never spent over $350 for one so $680 feels absurd.
Old Mar 8, 2023 | 07:11 AM
I don't know what your mechanical abilities are but if you can do such things, just replace it yourself. I can't imagine a quality battery being more than $300 +/-.
Old Mar 8, 2023 | 07:16 AM
Go you your local Napa store. Napa batteries are excellent quality, a new one is $240.00.
https://www.napaonline.com/en/search...ery&referer=v2
Old Mar 8, 2023 | 12:16 PM
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
Completely agree with the DIY: $240 https://shop.advanceautoparts.com/p/...agm/10866724-P
$1,114 is way too much . . . I had similar issues and replacing the battery made the electrical gremlins go away-- KH
Old Mar 10, 2023 | 04:44 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
It is frequently due to a seized exhaust valve.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Mar 10, 2023 | 04:49 PM
I_gotta_Vantage's Avatar
5 Year Member
I_gotta_Vantage is infamous around these parts
I replaced my OEM with diehard platinum in the link... IT IS THE ONLY AFTERMARKET AGM BATTERY THAT WILL FIT IN THE 2019+ MY. It has the same outer caseing and height as the OEM.
