New Vantage (2020) oil change, parts needed
Old Dec 18, 2023 | 12:22 PM
  #31
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
For those who might be interested, my AM dealer came back and said that the oil filter housing is a 24mm socket - KH
Old Feb 26, 2024 | 10:47 AM
  #32
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
Originally Posted by woodsalexj
Hi all,
Newbie here. Im trying to find out what i need for an oil change, other than the oil of course.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Can anyone confirm that I got what I need and the right parts?
Also hoping this might help someone else, it seemed hard work to get this info……
I just ordered the filter and crush washers you linked to for my 2020 Vantage upcoming oil change with Mobile 1 0w40.
Old Feb 26, 2024 | 10:56 AM
  #33
khiroshima's Avatar
The process is as easy as any other vehicle you have ever done - note my post above, grab a 24mm socket to get off the filter housing-- Cheers, KH
Old Feb 27, 2024 | 10:45 AM
  #34
MikeR397's Avatar
ya, looks super easy. I have the big socket kit from harbor freight for the filter housing tops. Looks like only issue people have is stripping the hex drain plug, so will be careful with that and make sure it’s the right hex size.
im adding an addition for a workshop with a 2 post lift and was hoping to do it on that, but looks that fall on the hoist and it needs done in the spring so floor jacks it is
Old Apr 16, 2024 | 11:57 AM
  #35
MikeR397's Avatar
Originally Posted by I_gotta_Vantage
7 liters isnt bad for a pump extraction. 7.5 is the wet fill.. . I only have 11K miles...
There is a trick I used to extract as most oil as possible... I put a rubber grommet on the hose that goes into the dipstick pushing it over the dipstick hole once the tube hit bottom and created a vacuum inside the oil pan pulling all the oil out. You run the pump longer, but you will continue to extract oil...
the actual oil capacity of a 2020+ vantage is 8.9 quarts, which is exactly what I got out removing the drain plug. The above post about suction the oil out is leaving a substantial amount of dirty oil in the car. It’s super easy to do it the traditional way, and very nice to have a dipstick (back left of motor).
Old Sep 30, 2024 | 11:14 AM
  #36
Bfarmer007's Avatar
Bfarmer007
Best Oil Vantage 2020 V8 ?
Tracking cars soon, what’s the best oil for a 2020 Vantage V8, I don’t drive in the winter time?
Sir Rothschild
Jun 17, 2022 05:30 AM
Ksa
Jun 17, 2019 12:19 PM
qu1Z
Tech / How To
Sep 10, 2014 07:20 AM
spainconection
Mar 30, 2012 12:57 PM
blayne
Aug 1, 2011 12:16 PM
